Question about HP Officejet Pro L7680 All-In-One Printer
HP L7580 printer prints mirror image
Out of the blue, this printer began mirror imaging--as if you needed it for an overhead projector.
Pls note that my only choice below is a 7680--and our printer is a 7580
  • 13 more comments
  • Anonymous Oct 17, 2008
    HP sent an update. I restarted my computer and now my HP7590 prints mirror image only. Please help!
  • mkardon1 Oct 20, 2008
    my printer prints a mirror page
  • shep6602 Oct 21, 2008
    Exact same problem with a HP L7680...It was printing fine this morning, then I installed SP3 for Windows XP and the mirror imaging began.
  • Anonymous Oct 22, 2008
    hp l7590 now prints mirror...???
  • pwhite1048 Oct 23, 2008
    How weird is that? I also just installed XP SP3 and now my printer is printing a mirror image. Anybody out there got any ideas/solutions?
  • Anonymous Oct 29, 2008
    I am having the same problem with my printer. All was fine and then I get mirrored copies. What do I have to do?
  • bjp50 Nov 05, 2008
    same problem that began after networking laptop to PC (one is XP and the other Vista) to hook to HP J5780 all in one
  • kevinf54 Nov 10, 2008
    We have a HP L7680 & PC running XP SP3, After the
    installation of the SP3 the mirror image problem started and I cannot get rid
    of it..
  • Philgo Nov 15, 2008
    I have just installed SP3 and have the same problem. I can clear the 'mirror image mode' by printing a test page on the printer which resets the 'mirror image mode' - until it happens next time!!! This suggests that a wrong escape sequence is being sent to the printer.
    I have turned of the Mirror Image setting in my advanced settings - it still prints a mirror image. The fix is no good for me.
  • max_s212 Dec 31, 2008
    I print from a Vista Laptop to an XP Desktop. HP3840 shared network printer. Comes out mirrored every time. Can't solve the problem
  • Anonymous Jan 07, 2009
    The 7680 continues to print mirror image even though the settings are correct. This is a networked printer/fax.
  • mwhitney6 Jan 18, 2009
    Same problen. Deskjet connected by USB to PC with XP. Second PC with Vista added to network prints to DJ6540 prints mirror image. All Mirror Imade boxes unchecked. (Checking a mirrir image box does not mirror the mirror!)
    Note: based on othewr posters this appears to be a common problem with mixes XP and Vista networks and HP printers.
  • terrysoe Mar 18, 2009
    when printing excel spreadsheet they all print out in a mirror image on hp officejet pro l7580. have checked that mirror image box is ********** any other pointers thanks!
  • Anonymous May 05, 2009
    I have the same problem, it seems if I am printing double sided for the first time I don't have a problem. Once I select the single sided, then back again I get this mirror printing effect. Any one with a solution please.
  • Go to the Printers Menu and select Add Printer
  • Add a Local Printer
  • Create a new port - type: local port
  • For the port name, enter the share of your printer on the remote computer.  For example, if your computer name is superDesktop and the printer share name is megaPrinter, you'd type in \\superDesktop\megaPrinter.
  • Finish the wizard and you're done, printing normally!
Posted on Jan 28, 2009
That only works once. After rebooting the "mirror image on" problem comes back. How can I permanently turn it off?
Thanks
Posted on Nov 16, 2008
Perfect fix and so simple!
thanks!!
Posted on Nov 07, 2008
  • HP Master
  • 419 Answers
You need to update your drivers to the latest version as this is a bug with the older drivers and the default "duplex" / "two sided printing" shortcut.
The problem and solution is provided here:
http://www.fixya.com/support/t1641997-mirror_image_printing
Posted on Feb 14, 2009
Go into your printer options and look under advanced. There is a box that can be checked "ON" for mirror image. Use the dropdown menu to change the option to "OFF". This worked on my printer.
  • pjroberts1 May 30, 2011
    On my HP printer it called this option "Flip horizontally" which then works as above.
2 Suggested Answers
sanjay_tech
  • 20 Answers
SOURCE: HP L7580 printer prints mirror image
Turn the mirror image option to on. If it does the same turn it off than uninstlall and reinstall the complete software.
Posted on Jan 26, 2009
Mirror image printing with my HP L7580 printer
You can access this when you click print, select either the options or properties button depending on os
You can also access this by righht clicking on your printer for properties
May 11, 2011 | Office Equipment & Supplies
When I print pics off my pic file, the pic comes out in a mirror image? I am using a HP Photosmart 3210 All-in-One Printer. Also when I try to print 4x6 pics from my files using proper HP paper, it tells...
When you go to print something next time, click on Preferences on the Print window. Click on the Advanced tab. There should be a Mirror Image choice and it probably says ON. Click on the ON and change it to OFF with the drop-down menu. Click OK. That should correct the mirror image problem.
As for the paper, I have a hard time printing on 4X6 paper too. Seems to be a common problem with HP. If you would like to accept the mirror image solution and post a separate on, you should get another expert to help you.
In the meantime I will try to research it further.
Thanks for using Fixya.
Dec 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
When you first click on print a window opens with boxes at the bottom. If you choose printing preferences another box will open where you can turn off mirror image printing.
Jul 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer is printing job as a mirror image
I would have said Gotta be setting in your print dialogue box, but if the test page comes out as mirror image, must be
a setting on printer control somewhere
Apr 21, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Mirror Image printing
This is caused by an early driver version provided with the printer.
Download the latest version from the HP website, unplug your printer from your computer then uninstall your existing driver. Once that's successfully completely install the new driver version.
Unfortunately this doesn't always resolve the problem straight away so you may need to repeat this.
To check if you've resolved the problem:
- Go to START > Printers & Faxes
- Locate your L7780 printer
- right click and choose "printing preferences"
- choose the "Two-Sided (Duplex) printing" printing shortcut
- click on the "Advanced" tab
- look at the setting for "Mirror Image"... If you've succeeded this should now be set to "Off"... If it's "On" you still have a problem.
The problem itself is caused by some duff default settings which seem to stick whenever you've done anything that uses the "Two-Sided (Duplex) printing" Printing shortcut provided in the printing preferences.
In particular I've seen this crop up with PDF files...
The new driver does seem to resolve this but a further work around is to define a new duplex setting that has the correct "Advanced" settings and has "Mirror image" set to Off.
This solution also works for the K5400, L7580, L7680, etc...
Feb 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Printing Backwards
You must have the Mirror image option turned on.
Open a document and select File>Print.
When the Print window opens, select the "Preferences" or "Properties". button.
Click on the Advanced tab. Look for the Mirror Image option. If it says "On", click on it and you will get a drop down menu to change it to "Off".
(BTW, the Mirror Image is used for printing iron-on transfers.)
Jan 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printer printing backwards on two users but not the main one
Compare the default printing preferences (Start>Settings>Printers and Faxes) Right-click on the printer icon and select Properties and Printing Preferences. Look for the option to print Mirror image used for printing T-shirt Iron-ons and uncheck the box.
Jan 03, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7555
When you select "Print" and get the print window to confirm....select "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
Dec 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
Aug 12, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
6,484 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
