Question about Panasonic Panafax UF-550 Plain Paper Laser Fax
Panafax 550 leaving heavey black lines on pages
Heavy black lines are being printed on to printed paper obscurring the printed word.
  • 24 Answers
Clean the optical area with a soft cotton piece of cloth and window cleaner. How does the cartrige looks like, if you see toner on the drum you may consider replacing the cleaning bladeand the drum if necessary. The cartridge was refilled?
Posted on Oct 14, 2008
I have a Panasonic Panafax uf-550 and I need to know how to receive a confirmation page
Apparently, you can set it for the default condition or you
can set it for the current fax you are sending.
To set the default:
1. Press "Function" then "74" then "Set"
2. Press "12" then "Set"
3. Press "1" for OFF
Press "2" for ALWAYS
Press "3" for INCOMPLETE only
4. Press "Set"
5. Press "Stop"
If you want to over-ride the default for the current fax,
1. Press "Function" then "8"
2. Press "1" then "Set"
Press "2" for ON (always print out)
4. Press "SET
Thanks to FixinFax for the clue for the default setting.
Alex Cook
May 21, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
Panasonic Panafax UF-550 not receivng faxes
Check your line for static, should sound a clear tone. 95% of communication problems are related to line quality (phone company fix this). The other 5% is the modem PCB of the fax machine
Feb 12, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Paul,
Seriously, fax machines are designed to have their own dedicated analog phone line.
You can get a fax/phone switch from Radio Shack to hanle this problem.
May 09, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Panasonic Panafax UF-885 - Heavy lined marks down side of paper
First print a report to see if the lines appear without using the scanner. If this is the case clean the charge wire. If you pin it down to the scanner, it is probably a poor solder joint on the cis unit. Take it out and run a hot soldering iron over all the joints on the reverse side of the cis.
Apr 15, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Confirmation Page
Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FG2451
Dec 10, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Fax does not print a confirmation page.
Use Function 8 not 6 and use set to lock it in. Lawrence
Nov 09, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Panasonic Panafax UF-550 Plain Paper Laser Fax Logo
108 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
