Question about Zanussi TD4112W Electric Dryer
Zanussi TD 4112 W Not warming up
My Zanussi TD 4112 W has stopped warming up. Everything else seems to be working ok.
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Posted on Oct 19, 2008
I bought a Zanussi ZKG2105 less than two years ago and all of a sudden it would not switch on. Checked everything, the fuse, the power outlet and the filters, everything seems fine but it just would
Try replacing the temperature sending unit in the back of it. Just 2 screws hold it on and 2 wires connected to it. It's just a round button style with a plate and 2 holes for screws to attach it. If it's bad, you'll get no heat to the element. Runs but no heat tells you this is the problem.
Sep 09, 2014 | Zanussi Washing Machines
Zanussi TD 4112 W....drier turns on and the heat comes put but the drum doesn't turn?
belt is broken drive pullt is off tension pully is broke
Nov 10, 2012 | Dryers
Ai need a new motor for zanussi dryer model no td
You'll need to contact Zanussi Service center in case you want to buy new motor, Visit this Link and put your postcode to locate nearby service center.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Zanussi TC7114W Electric Dryer
Tumble dryer TD 4112 W has power but drum does not turn - light is on and it makes humming noise but won't start.
hello the first thing to check is. the long pin on the inside of the door these sometimes snap off . if ok then check to see if the belt has come or snaped if ok then you may need to check the capacitor this next to the motor will have 2 wires coming off it these dry up good luck
regards
shaun
Jan 17, 2010 | Zanussi TD4112W Electric Dryer
Zanussi Tumble Dryer - TD 4112 -Door Catch Assembly/Repair The plastic catch broke and I have bought a replacement however I can't work out how to put the pin, spring and catch back together. Any help...
Jason, I have the same problem... the catch on my Zanussi dryer has broken. I've ordered a spare part... and remembered how I took the thing apart.
I'd have to show you... it can't be put into words. LOL
Hopefully by now you've figured it out. (Just seen the date you posted this).
~ Franka ~
Aug 31, 2009 | Zanussi TD4112W Electric Dryer
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Feb 16, 2009 | Zanussi TD4112W Electric Dryer
Zanussi Tumble Dryer Model TC7103W ** Heat
have u changed the thermostats if not change these these r what let the heater element get warm if this then works then the element u changed will more then likely be OK m8
Mar 10, 2008 | Dryers
Zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Jan 26, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi TD4112W Electric Dryer Logo
441 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
