Question about Carrier Heating & Cooling
Carrier air handler tonnage?
I apparently have a mismatched split system. The outside condenser unit was replaced with a 1 1/2 ton condenser. The original system is a Carrier, the inside air handler model number is FF1CNA030, which I take to be a 2 1/2 ton system, which needs a 2 1/2 ton condenser unit
Please help Mark
  • 3 Answers
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Posted on Oct 14, 2008
  • utah300rum Oct 14, 2008
    If you would like to give me the state and town you live in I may be able to contact a Carrier representative, that may be able to recommend a good HVAC dealer.
    Good Luck
  • gtimm6915
    gtimm6915 May 26, 2012
    Are you still out there with info on Carrier HVAC dealers?? I live in 62206 zip code area.....know anyone that could help me find an air conditioner and have it installed? Sadly to say, but mine was stolen when the (prior) owners of the house went to FL for the winter ...so it was purchased by me with no air....NOW I need air in the house!!! Can you help? It is an older Crusader Carrier.
Your outside condenser unit must be a 030 model. or 30000 btu
Posted on Jan 15, 2009
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
I have a Carrier Weathermaker model #38tdb060300 A/C system. How many tons is that? It is 11 yrs old, capacitor exploded and compressor is blown. Needing to replace.
Looks like a 5 ton unit. However, you might be better off finding a R-22 condensing unit to replace the entire outside unit. Reason being, if you just replace the compressor, you get a one year warranty. If you replace the whole outside unit, you get a 5 year warranty. You can replace the outside unit with any manufacturer, as long as it is the same tonnage and type (heat pump/air conditioner/single stage/ 2 stage ...).
Oct 13, 2014 | Heating & Cooling
Rcba 4882g how much is it to replace the central AC condensing unit
This will be dependent on the capacity (tonnage or BTU/Hr) of the condenser, its location and how much refrigerant will be needed to added / replaced - plus the labor to do it. A typical 2 - 3 ton residential system (air handler / condenser - no duct work, etc.) can run $2k and up.
Jul 04, 2014 | Rheem Heating & Cooling
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
Need to know the tonnage ofCarrier s/s Model #38ARZ008, ser # 1404G20031
Brand: CARRIER Manufacturer: CARRIER CORP SYRACUSE Model Number: 38ARZ008(5/6)0 Condenser Type: air-cooled Coil Model Number: 40RM-008--B5/6GC System Configuration: Split System Air Conditioner Energy Efficiency: 10.6 EER Cooling Capacity: 90,000 BTUs / hour ARI Type Code: RCU-A-CB Electrical Service: Triple-phase Electrical Input: 8,490 watts per hour Voltage: 230 and 208 and 460
12000 btu's per Ton, equals to 7.5 Tons.
Sep 29, 2010 | Carrier 38CKC042 Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
What tonnage are these units and is it a variable speed.
The heat pump model number shows that it is a two and a half ton unit. I am sorry but I am not familiar with the air handler model number.
May 07, 2009 | Heating & Cooling
I am looking for the tonnage for a carrier air handler FX4cnf002
3 and 1/2 tons=42,000btu. Based on the info you posted that is your tonnage. Unless someone did a mis-match on your system for some reason.
Apr 11, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
1,223 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
