Question about Sharp AR-M205 Copier
Switch the way the paper comes out of the machine
Recently I down-loaded new updates from Windows on line, after the updates I could not access my files. My computer guy came over and fix the problem, however there ar a few minor problems still .
How can I swich the paper from copying landscape to portrait, I've tried with the regular printing boxes on Word but no change.
Also when I makea copy the copy comes up short, either the top is cut off or the bottom. Any suggestions? Sharp AR-M205
  • 24 Answers
You may try in control panel, printers and faxes, right click, prinetr properties, page setup.
Posted on Oct 14, 2008
    Scholar:
  • 92 Answers
Sounds like your tray settings are incorrect. Make sure that if the tray is set to 8 1/2 X 11 in the menu settings(not 8 1/2 X 11R) that the paper is set in the tray to feed the long edge first. The machine is capable of automatically rotating the image to fit the paper as long as the paper is set correctly.
If you prefer to feed short edge first then set it for 8 1/2 X 11R.
My fd 400 credit card machine not recognizing paper
you need to make sure the paper is thermal. you can test by scraping on the paper with your nail. if a black line appears that is the thermal side and it should face down in the paper loading tray. if the paper is new try another role and or turn it over, but it has to be credit card machine thermal and not calculator paper
Jan 29, 2014 | Office Equipment & Supplies
I can't update the bios on my latitude e5510
If you use the dell web site, allow dell to search for drivers on your machine. If there is an update, down load it and it will install when you click on the file.
Jan 20, 2014 | Dell LATITUDE Computers & Internet
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
Last windows update now I can't boot it up. Window screen comes up and then shuts the computer down and statr all over again
Ensure NO media is plugged in first ie CD / mem stick.
May not be the Windows update. try booting into safe mode using F8 key, if you can access windows that way then problem is a program thats trying to load. To stop programs from loading go to safe mode
If windows wont load in safe mode then registry is corrupted.
Jan 26, 2010 | Toshiba Satellite A85-S107 Notebook
Dell Vostro 1500 won't boot after downloading updates
What programs are installed on the machine? there may be a file that's conflicting with one of the updates. You may leave automatic updates turned off. Looking for the culprit will require and will be easier if a tech will check the computer onsite or thru remote access.
May 02, 2009 | Dell Vostro 1500 Notebook
I renewed my and paid for it to down load the update, however could not complete to down load the update. At the end this is what come out. "aborting installation. Error 1601. The window installe svc...
Try going to windows update, click on "use administrator options" and download windows installer redistributable 3.1 Run this, and it will fix your windows installer. Then you should be able to re-install your program. Be sure to remove the half-installed one first, though, because it might cause problems with your new install.
Feb 21, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Paper jam
The various parts that open up to allow access are monitored by a micro switch. Switch the machine off and open all the access points locate the switch and make sure it is freely working and the connections are all in place. Then come back
Jun 06, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Sharp AR-M205 Copier Logo
164 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
