I have a mitsubishi 1080p wd-52631 i just replace the lamp 1 month ago now my tv shows no picture but i here the sound and when i turn the tv off it sounds like something is still running for a few seconds?
    President:
  • 1,952 Answers
I think voltage not get in to ur video board..check that..
thanks for using fixya
Posted on Oct 14, 2008
  • 1,879 Answers
After unplugging it and leaving it off enough to let the lamp cool down, re-seat the lamp.
  • 19,396 Answers
Try first unplugging power cable for twenty or thirty minutes, if that does not work it means that the TV has an internal problem, and should be inspected by a technician.
    Sergeant:
  • 352 Answers
Hi lil,
I don't have a clue what could be wrong but some one here might:
Mitsubishi Electric & Electronics USA, Inc.
Americas Corporate Office
5665 Plaza Drive
P.O. Box 6007
Cypress, CA 90630--0007
Phone: (714) 220-2500
Facsimile: (714) 229-3854
E-mail: CustomerCare@meus.mea.com
anaanymous
I HAVE MITSUBISHI WD-73640 AND ITS SHOW THE GEEN LIGHT BUT DOESN'T HAVE PICTURE OR SOUND
The first thing to replace is the lamp. Google your model number and "lamp" and you'll find several sites that sell them. It isn't difficult to replace yourself and isn't very expensive. Good luck.
Sep 25, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
Red lamp light is ON
If you google the model number and lamp you should get a better price and usually get one in just a few days.
Mar 17, 2012 | Mitsubishi WD-52631 52" Projection HDTV
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
The picture on our Mitsubishi 1080P went off but
Ur tv have been on using like 4 or 5 hours a day?This tv have not been replaced it projection lamp?The lamp in the tv used like a 1 or 1 1/2 years?The projection lamp life is over,replace the lamp.
Jun 15, 2010 | Mitsubishi WD-60735 Projection Television
WD-52631 Audio works, but no picture
Probably a bad lamp. This is the first thing I would try....especially if the lamp has not been re[placed in awhile.
Oct 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No video. Sound OK
I felt it would be best to re-post on this to give some closure. Most people post their problems and after the fix has been applied, people who are in the same boat never hear if a fix worked or not. It ended up just being the lamp bulb. I purchased a replacement bulb on eBay, did the removal of the bad bulb and install of the new one via the aid of a video provided by the reseller. It took about 10 minutes over all to fix and I'm happy to say that my TV is working just fine.
Jan 07, 2009 | Mitsubishi WD-52631 52" Projection HDTV
Smell from mitsubishi wd-52631
Hi...maybe I can help. Go back in and make sure your lamp is connected to the ballast. If it is not all the way in, it will smell like it is burning. Sometime it will even burn out you lamp and or ballast too. Good luck
Mar 28, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
