Question about Minolta CF2001 Copier
Minolta CF2001 C410 error code
Hello!
I have a C410 code on a CF2001! How can I reset it? Excepting the procedure of counter reset from the Service Mode. All teh parts implied in the structure of this code were changed - exposure lamp, image processing board, connectors, lamp fuse...no response. The code won't reset!
Any ideas???
Petru
  • 145 Answers
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: after opening the front door, it is in the lower right corner.
2. Insert a suitable object into the hole to actuate the reset switch.
HOPE THAT HELP
LET ME KNOW
Posted on Oct 19, 2008
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
My sharp color copier Mx 3100n is indicating F2-73 after using 88-1 how do I restore it
Hello Tijjani,
The error code that you are experiencing is as follows;
F2 73 IMPROPER TONER CARTRIDGE DETECTION (YELLOW)
You need to replace the yellow cartridge with the proper part # Item Number: MX 31NTYA, MX31NTYA.
Good Luck!
Rich Lilja
Jan 08, 2017 | SHARP MX-3100N
Sharp ar gives me error number h4 how to let it work again
The error H4 stands for the heater roller H3 (Fuser) temperature is low and probably burnt out. You need to call for service.
Jan 08, 2017 | Sharp Office Equipment & Supplies
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
How to set two sided printing in konica minolta pagepro1390MF
It might be better to place this problem in the computer section.
Oct 17, 2013 | Office Equipment & Supplies
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
246 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
