Question about Xerox DocuMate 252 Path-Through Scanner
ADF pad How do I order an ADF pad?
    Scholar:
  • 91 Answers
The ADF Pad part number is 57-0103-000.
Their online ordering has a kit with 4 pads and cleaning accessories for a price of about $100.00. The part number for this is 96-0201-000.
To call direct:
The 1-800-648-0410 customer service call center provides product information and online order management services for Xerox Departmental, Workgroup and Photo Scanner products.
Call 1-800-648-0410
Monday - Friday (except holidays)
6:00 a.m. - 4:00 p.m. PT
Let me know if this has help and thank you. Binary Bob
Posted on Dec 10, 2008
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
HP Officejet Pro LP 7880 feeder does not work, how to fix it?
Step one: Check the paper in the ADF The condition of the paper or the amount of paper loaded in the ADF might prevent the ADF from picking it up and feeding it through the product.
  1. Make sure that no more than 50 sheets of paper are in the ADF input tray.
  2. Make sure the original is not photo paper or carbon paper. These types of originals must be loaded on the scanner glass.
  3. Make sure the original document that is loaded in the ADF meets the following criteria:
    • Free from curls, folds, creases, and tears
    • Does not have staples or clips attached
Step two: Make sure the ADF pick assembly is in good working condition
  1. Remove the document feeder and open the ADF cover.
  2. While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
  3. Examine the pick assembly.
    • Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
    • Make sure the stack stopper, which is located between the top and bottom rollers, fits within the double slots just above the bottom roller. The stack stopper should move freely within the double slots to flow up and down when the whole pick assembly is lifted and lowered into position.
  4. Return the pick assembly to its original position.
  5. When the product is turned on, the top roller will reset to its original position above the separator pad. There will be a gap between the separator pad and the top roller.
  6. If there is no gap between the ADF top roller and the separator pad, press the Power button to turn off the product.
  7. Wait three to five seconds and then press the Power button to turn the product on. The ADF rollers should reset to the correct positions.
  8. Close the ADF cover and replace the document feeder.
Step three: Clean the rollers and separator pad
  3. Lightly dampen a clean, lint-free cloth with distilled water, and then squeeze any excess liquid from it.
  4. Use the damp cloth to wipe any residue off the rollers and the separator pad. If the residue does not come off using distilled water, use isopropyl (rubbing) alcohol on the cloth instead.
  5. Return the pick assembly to its original position.
  6. Close the ADF cover and replace the document feeder.
Step four: Detaching and re-attaching the ADF pick roller assembly If the ADF pick assembly is detached or not connected properly, follow the steps below to resolve the issue. If the ADF pick assembly works well, do not perform these steps.
  1. Press the Power button to turn off the All-in-One.
  2. Remove the document feeder and open the ADF cover.
  3. Press the blue-green ADF-release button to release the ADF rollers from the pick assembly as shown in the figure below (the red arrow is pointing to the ADF release button).
  4. Re-attach the ADF pick rollers by placing the rollers into the roller slot of the ADF pick assembly as shown in the figure below. The red arrows show the gears on the ADF pick assembly aligned on one side. The yellow arrows point to the two-catch notch.
  5. Once the rollers are placed on the two-catch notch, push them in, so that the two-catch clicks into place. The photo below shows a correctly installed ADF pick assembly.
  6. Close the ADF assembly and cover.
  7. Turn the product on and make a copy with the ADF to check that the pick assembly works.
Jul 16, 2010 | HP Officejet Pro L7680 All-In-One Printer
The MFX2830 adf pulls the paper crooked when feeding.
check ADF rollers and re-feed pads.(maint cycle approx.50~80K)
Also check ADF is square on copier..sometimes people push on ADF when moving machine and get ADF out of alignment.
Mar 03, 2010 | Muratec MFX-2830 Black and White Copier
Image class 780 ADF jamming problem
The problem could be with the ADF rollers. First open the top ADF cover and clean the rollers gently with some isopropyl alcohol on a soft cloth, let dry for about 10 minutes. Also check to see that the top seperator pad is not worn out. This pad should be cleaned as well. If this does not work the ADF rollers and the seperator pad will have to be replaced.
Sep 08, 2009 | Canon imageCLASS D880 All-In-One Laser...
I need parts exploded view for adf or just part numbers for all rollers in adf
FM2 - 0015 - 000 - SEPARATION ROLLER UNIT
FC5 - 0009 - 000 - ROLLER, PICK-UP
These next three part go together:
FL2 - 0006 - 000 1 PAD MOUNT UNIT
FC5 - 0042 - 000 1 PAD, RUBBER
FC5 - 0044 - 000 1 PAD, SPONGE
Aug 04, 2009 | Canon imageCLASS D880 All-In-One Laser...
The document paper is crumpling as it enters the Fax Machine? I have cleared any old pieces of paper but it continues to crumple the paper???
In order for the documents to crease when entering the adf, there must be an obstruction. Since you have not mentioned the machine you have there it's harder to help. But, if you inspect the rollers and separation pad inside the adf, you may see that the sep pad has been dislodged or bent backwards or the rollers are dirty. If there is a sensor flag on your model, it may be stuck. Maybe there is a paper clip stuck somehwere along the paper path..
Jul 06, 2009 | Office Equipment & Supplies
HP7310 ADF will not load paper
When you say you have cleaned the part have you taken the ADF and opened it and cleaned the rollers and seperator pad? Document with parts labelled is here;
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00222165&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=391182
If you have done that and still no feeding then you may need a new adf. You can call hp but the easier way is to order it through the HP Part Surfer - the part number you need is Q3462-60276 and it costs $25.65 according to the site at the moment.
Dec 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Problem with the adf documate 510
Check the adf pad assembly. It is the small grey pad inside the top cover. One replacement pad should have come with your scanner. Mine was doing the same thing, when I replaced the pad, it worked like new.
Jul 28, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
8820DN hinge problem
To answer Meyerson's questions:
My symptoms did not include papers jamming in the ADF -- in fact, the ADF didn't work at all due to the broken left hinge.  :(  Also, I don't recall having any unusual problems with the ADF jamming frequently before the hinge broke to the point where the ADF didn't work at all.
I obtained the replacement ADF left hinge assembly by searching online for a parts dealer.  I believe I ended up ordering the part from Precision Roller.
I hope this helps,
-Barb
Apr 01, 2008 | Brother MFC 8820D All-In-One Laser Printer
Canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
Jan 15, 2008 | Ricoh Aficio SP-C210SF Printer
Xerox DocuMate 252 Path-Through Scanner Logo
722 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
