Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fault Code "HE"
I can't find a reference to this code
  • 27 Answers
"HE" is not a fault code, it justindicates that the machine is heating the water. Does the machine complete the cycle?
I hope this helps
Posted on Oct 25, 2008
I have a 2003 S-type jaguar that goes into a limp mode and stops running then the engine system fault shows ,the parkbrake fault and DSC not available also shows. Diagnostic showed codes PO121,P1582??
code p 0121 is associated with the throttle position sensor and accelerator position sensor
causes are from cable adjustment --throttle position and accelerator position sensors
code p0533 refers to ac refrigerant pressure sensor--high input== causes --ac pressure too high (cooling fault -condenser fan not running at radiator-- too much gas --pressure sensor
p 0105 refers to map sensor / barometric pressure sensor --circuit malfunction===causes wiring--- map sensor --baro sensor ECM
code p0566 refers to cruise control master switch== causes --control switch , ---ECM
code p1582 refers to electronic throttle monitor data available which will be associated with the p 0121 code and faults
Jan 08, 2017 | Jaguar Cars & Trucks
How to fix obd2 trouble code P1680 on a 2004 Isuzu ascender 4.2l eng
code p 0300 refers to random/ multiple misfires detected ===causes --spark plug/s--HT lead/s--injector/s --ignition coil/s--low compression --wiring
most likely low fuel pressure and injector problems
code p 0442 refers to evaporative emission (EVAP) system ---small leak detected ===causes hose connection/s--intake leak-- EVAP canister ---EVAP canister purge valve
it also refers to --large leak detected ===causes ---petrol cap loose ,/missing---mechanical fault ---EVAP pressure sensor
code p 0455 refers to EVAP ---large leak detected --all those stated plus EVAP canister purge valve
code p1680 refers to electric throttle control (ETC) monitor ---processor fault ===causes --wiring--ECT monitor
Sep 30, 2016 | Isuzu Cars & Trucks
WHAT DOES FAULT CODE 676-4 REFER TO?
WHAT DOES FAULT CODE 676-4 REFER TO? - Fixya
www.fixya.com/cars/t25801863-fault_code_676_4_refer
Jul 30, 2015 - ... 676-4 REFER TO? HYSTER FORKLIFT 3.0 FORTENS ENGINE 3STAGE WITH SIDE SHIFT FAULT CODE 676-4 - Cars & Trucks question.
FORKLIFTACTION.COM (Forklifts) - Site Map - List all forum ...
www.forkliftaction.com/sitemap/forums.asp
Find forklift manufacturers, dealers, suppliers and other lift truck ... What do we know about the PSI 2.0L and 2.4L engines? .... nissan platinum error codes. ..... what have change do I all to go at hyster forten truck of montrol pendaal to ..... Raymond EASI - NO reach, tilt, or sideshift. ...... Hyster 5.5FT fault code 676-4 [view]
Jul 30, 2015 | Cars & Trucks
What does codes 54 and 55 mean on my 2001 freightliner columbia 60 series detroit
code 54 (DDC#( flashed ) refers to vehicle speed sensor fault
code 55 (DDC# flashed)refers to other ECU fault ( this fault is logged in conjunction with another fault to indicate missing information from another ECU. it also refers to J1939 data link fault
May 19, 2015 | Cars & Trucks
P0313,p008A,p0087 . I don't understand this codes from my Lr4 2010
code p0313 refers to misfire detected---low fuel level===causes-- fuel system ---mechanical fault ( check fuel pressure, fuel filters and fuel pump)
code p0087 refers to fuel rail /system pressure --too low=== causes --fuel pump,--fuel pressure regulator--fuel supply line blockage--mechanical fault. ( have the fuel system pressure tested.)
The code you have listed as p008A is not in the book and you have not given an make or engine model to refer to in other places. I will refer to the code as p0084 which refers to exhaust valve control solenoid, bank 2--circuit malfunction===causes --wiring--exhaust valve control solenoid---ECM ( this will present as a rough running engine or problem starting/ shutting down
Oct 30, 2014 | Cars & Trucks
I have a 2007 ford taurus with p0300-p0303, p0306, p0316, p2195 and p2196. engine doesnt start anymore but battery is fine.
The old give me money for nothing statement from a mechanic instead of knowing how to fix it.
code p0300 refers to random/ multiple cylinder/s misfire detected===causes--spark plug/s---HT lead/s---injector/s---ignition coil/s--low compression--wiring
code po303 refers to cylinder 3 misfire detected--- engine mechanical fault---wiring---ignition/ fuel system---injector --ECT/MAF sensor --- ECM
code p0306 refers to cylinder 6 misfire detected===causes --engine mechanical fault---wiring---ignition / fuel system---injector ---ECT/MAF sensor---ECM
code po316 refers to misfire detected during start up--first 1000 revs==causes--engine mechanical fault---wiring---ignition /fuel system---injector
code po2195 refers to heated oxygen sensor (HO2S) 1 bank 1 signal stuck lean===cayses ---HO2S---fuel pressure---injectors---intake leak
it also refers to O2S sensor 1 bank 1 same causes and also refers to HO2S 1 bank 1 implausible signal===causes --- short to positive---short to ground---Ho2S ---ECM
code po2196 refers to the same items as 2195 . some causes are also air intake restricted
Have a compression test done some where else and it will indicate the condition of the motor. The rest is sensors and wiring problems.
Jan 05, 2014 | Cars & Trucks
Have a 2005 f-150 5.4.having trouble with codes. p0053,p0203,p0303 and pO453. Where to start and can u fix one thing to cancel out 2 or more codes.
code p0053 refers to heated oxygen sensor (HOS) bank 1-circiut malfunction===causes --wiring --- HO2S
code p0203 refers to injector 3 circuit malfunction==causes---wiring--injector ---ECM
code p03030refers to cylinder 3-- misfire detected===causes--engine mechanical fault--wiring---ignition/ fuel system---injector---ECT/MAF sensor---ECM
code p0453 refers to Evaporative emissions(EVAP) pressure sensor--high input==causes---wiring short to positive--EVAP sensor---ECM
code po203 and po303 both have injector as possible fault but the others you will have to fix separately. I doubt an ECM fault as there would be more problems evident so check that one last as it big dollars.
Sep 22, 2013 | Cars & Trucks
Fault code 1600
code 1600 refers to throttle position (TP) sensor-communication error. Cause wiring---poor connection---TP sensor---ESP control module---ECM
code 1000 refers to barometric pressure (BARO) sensor --signal high. Cause---wiring short to positive---BARO sensor.
Apr 08, 2013 | 2008 Volvo S40 2.4
Is there an erg valve on a honda accord 2008 4 cyl
code p0300 refers to--random/multiple cylinder/s misfire detected...Causes---spark plugs---HT leads---injectors---ignition coils ---low compression ---wiring
code p0302 refers to cylinder 2 misfire detected Causes ---engine mechanical fault---wiring---ignition/fuel system ---ECT/MAF sensors ECM
code po303 refers to cylinder 3 misfire detected Causes Engine mechanical fault---wiring---ignition/ fuel system ---injector---ECT/MAF sensor ECM The common fault to all is the fuel/system ignition
I would have the injectors checked and have a pressure test done on the fuel manifold to check pump and fuel regulator valve.
Apr 05, 2013 | 2008 Honda Accord
Hi my Saab 2001 93 2.0 turbo convertible has lost power get into limp home mode I reset it every few weeks codes come up p1105 p1260 p1251 p 1264 what do u think is wrong ?
code p1105 refers to manifold absolute pressure(MAP) sensor, TC system-leak detected. causes ---intake leak, ---hoses There are to references to p1105 The second response is still map sensor but the causes are---TC system--mechanical fault--air leak between throttle body-TC,map sensor---TC system--exhaust blockage
code p1260 refers to throttle return spring--weak spring force. causes ---mechanical fault,--,throttle control unit
code p1264 refers to throttle valve opening-accelerator released causes ---throttle control unit---mechanical fault
Mar 28, 2013 | 2001 Saab 9-3
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
108 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
