Question about Zanussi TD4112W Electric Dryer
Zanussi TD4122w Electric dryer stopped warming up.
I have a Zanussi TD4122w Electric dryer but it has stopped warming up. Everything alse seems to work correctly
  • Kris Seymour May 11, 2010
    Do you still have a problem?
3 Suggested Answers
Timon90
  • 126 Answers
SOURCE: zanussi z910r electric dryer
Maybe the fan is broken. Or clogged with lint.
Posted on Jan 25, 2008
SOURCE: Zanussi TD 4112 W Not warming up
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Posted on Oct 19, 2008
Electric dryer
Check lint filter and exhaust hose for clogs, clean and make sure it's clear.
Oct 11, 2014 | Zanussi TD4212W Electric Dryer
My hotpoint dryer has. stopped spining everything rlse is ok please help model TLS61p
Do you hear the motor running? If so then it is probably just the belt that has broken...if there is no motor spinning, then the motor may have become defective or the start capacitor may be bad causing the motor to not start
Mar 03, 2011 | Zanussi TC7102W Electric Dryer
My tumble dryer has stopped working, the drum was going forwards, but not in reverse, not it seems as if it is stuck
Sounds like a belt slipped off the pulleys in the back or broke. Remove a few screws on the back panel and it will be very obvious.Good Luck
Sep 19, 2010 | Zanussi TD4100W Electric Dryer
I HAVE A ZANUSSI TUMBLE DRYER TC 7103 W, ELEMENT SEEMS FINE, THERMO ALSO FINE BUT STILL NO HOT AIR BEEING CIRCULATED
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 20, 2010 | Zanussi TC7114W Electric Dryer
Reset button
your heating element may have burned out
Jun 17, 2009 | Zanussi TD4112W Electric Dryer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
TD 4112W Dryer does not auto reverse
my new dryer makes athumping sound when in use and it sounds like a pair tennis shoes are being dried
Feb 16, 2009 | Zanussi TD4112W Electric Dryer
Zanussi dryer belt sometimes rotates then stops
is the belt tensioner adjusted corretly? and belt on straight?
Dec 30, 2008 | Frigidaire GLER642A Electric Dryer
Oct 14, 2008 | Zanussi TD4112W Electric Dryer
Zanussi TD4112W Electric Dryer Logo
53 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
