Question about Apple iPhone Smartphone
How to lift sim port access area
I can see location of sim card but how to i open it
  • 282 Answers
This might help, dont forget to rate this post as fixya! thanks
Posted on Oct 14, 2008
Insert sim
A SIM card in a cell phone or smart phone is a small plastic card with circuits on it. This card holds the user's account information, which allows the cell phone service network to find and connect to the phone. It also contains the user's directory and such other stored data as photos, files and text messages. A rejected SIM card will cause the phone to malfunction. This can occur if the card is damaged, wet, dirty or dislodged.
1.Locate the SIM card on the phone. Generally the card is stored under the battery. You'll probably have to remove the back cover before you can slide out the battery. Be sure the phone is turned off before doing this.
2.Remove the battery and look for the SIM card. It is usually white or yellow with circuitry printed on it. Sometimes it has text on it as well. The card may be as small as a thumbnail.
3.Remove the SIM card, which is usually held in place by a metal clip. To unlock the clip, lift it up or slide it up or down. Gently lift or slide the SIM card up and out of the clip. You may need a pair of tweezers.
4.Blow around the area where the SIM card had been lodged to disperse any dirt or dust.
5.Look for any water, dirt or grime that may have gotten into the phone or on the SIM card. Use a soft cloth to gently wipe the SIM card, the battery and the area around the SIM card compartment. Make sure to use a fine cloth that will not tear or catch on circuitry and other metal parts.
6.Inspect the SIM card for damage such as cracks. If the SIM card appears undamaged, firmly return it to its home in the clip. The SIM card circuitry should be face down so that it is touching the metal connectors on the phone. Slide the clip back into place to secure the SIM card.
7.Replace the battery and any casing. Turn the phone on. If the SIM card has been cleaned and properly placed back into the phone, it should function properly.
8.Contact your cell phone service provider if the SIM card is still rejected. You may need to replace it.
I hope you find it very helpful.
Aug 27, 2011 | Nokia 1616 Cell Phone
Where is the sim card and how to get it out
Depending on the model, and manufacturer the SIM is generally located under the battery.
To access the battery, open the back panel, take out the battery. You will see a silver metal shaped sim card cover, lift/slide it and place your sim card.
Be sure to read your phone manual as this always shows how to insert the sim.
Jul 06, 2011 | Cell Phones
How can i remove my sim card to my nokia c7?
The SIM card is located beneath the battery pack. You must release the back cover latch, lift it up, remove the battery pack, and, then, access the SIM card slot. Please, refer to pages #8 and #9 of your phone's user guide (which you can download from this location, in case you happen to miss it) for further details.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 11, 2011 | Nokia C7 (8 GB) Smartphone
On my nokia n97 there is a lttle envelope flashing at the top of the screen which means sim memory full, how do access this to delete the messages
ok read and do it carefully
you can remove this icon by followng steps
Press Menue Button
Open Messeging
Now Press Options
choose SIM Messages
Mark All Messeges and copy to INBOX
Mark all again and Delete all messages
Press Back button
Little envelope flashing will no more
Thanks
Mar 07, 2011 | Nokia N97 Cell Phone
Sim card rejected mobile no.9592607262
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 14, 2011 | Computers & Internet
How do I remove the Sim card from a Motorola Razr V3M cell phone?
it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
Good luck to you.
Mar 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
How do I remove the battery and put the sim card in my new nokia 2760 cell phone
These are steps from the Nokia 2760 manual found at :
http://nds1.nokia.com/phones/files/guides/Nokia_2760_UG_en.pdf
(pages. 12-13)
1. Press and slide the back cover toward the top of the
phone to remove the cover .
2. To remove the battery, lift it as shown
3. Carefully lift the SIM card holder from the finger grip
of the phone, and open the flip cover
4. Insert the SIM card, so that the bevelled corner is on
the upper left side and the gold-colored contact area
facing downward.Close the SIM card holder, and
press it to lock it into place
5. Insert the battery into the battery slot
6. Align the back cover with the back of the phone. Slide
and push it toward the bottom of the phone to lock it
Apr 14, 2009 | Nokia 2760 Cellular Phone
Motokrzr sim card
Yes, you can use the same SIM card on a Blackberry and Motokrzr
To access the SIM Card on Motokrzr, slide open the back cover and remove the battery. The SIM card is located towards the top side of the phone
Dec 10, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Installing sim card in sidekick II
hello, hope these instructions help: 1. To expose the SIM card slot, peel back the bumper from the top-left edge of the device. (fig 1) 2. Insert the SIM into the slot with the gold contacts facing forward and the cut corner facing out. (fig 2) 3. When you release the SIM, make sure it is locked into position behind the catch so it will not spring out. 4. Replace the bumper and turn on the device. Any problems, let me know :) Si
Oct 03, 2007 | T-Mobile Sidekick ID Cellular Phone
Apple iPhone Smartphone Logo
29 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
