Question about Philips Magnavox 42MF521D/37 Television
No picture but has sound
My Vizio 42 inch made a loud cracking sound and then the picture went out. I still have sound but the picture won't come back on ? I have a chance to receive a free Magnavox 42" Plasma television that after about 16 months went dark on the picture but still has sound. I wanted to see if this would be worth getting fixed or would the money spent be better spent elsewhere?
  • Philips Master
  • 19,396 Answers
Regarding the Plasma TV with dark picture, this is often caused by bad sustain board, replacing the Ysus Zsus kit may solfe the problem.
Regarding instead the Vizio with sound but no picture:
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 05, 2009
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
42" vizio vw42l - no picture or sound
If the backlights for the screen do come on and you also have 12v and 5v feed the main board then it does sound like the mainboard will need to be replaced.
Nov 28, 2009 | Vizio VW42LF 42 in. LCD HDTV
LG 42'' Plasma 42PC1DV loud pop,buzzing, no picture cracked screen
pdp panel cracks need replaced
Manufacturer LGE 42PC1DA Part Number EAJ42047868 Description 42 INCH_XGA PDP MODU
Manufacturer LGE 42PC1RV Part Number EAJ42007501 Description PDP,MODULE-VGA
Oct 04, 2009 | Televison & Video
I have a 42 inch vizio VW42L and a few months after I bought it sometimes when I go to turn the set on I get sound but no picture. To the point where the backlight of the tv doesnt even turn on. I usually...
Tell Vizio send out the tech.to replace ur Backlight video inverter board,it dying go to be dead sooner or later.Or take the refurbished tv ur tv will have dead video soon.
Sep 07, 2009 | Vizio VW42LF 42 in. LCD HDTV
Sound will go to loud static noise, but picture is fine
it sounds like you need someone to look at it for you so fix it under warrenty if you can. Maybe buy a set top box and source your sound from there. also buy 5.1 surround (if you like as its a excuse to upgrade) for your speakers.
Jun 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
hey twinbrother, sounds like we have the exact same issue, i'll let you know if i figure anything out. sure seems like it blew a fuse or something?
Mar 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 42 inch Lcd tv
You need an Vizio authorized TV repair guy to check out the problem for you.
Solutiondoct
Oct 12, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
With all the listed sets,itis most likely the y-drive(sus) board.The only problem is that this board usually fails when the horz.buffer ic's fail,which is usually part of the plasma display.This was a semi-common problem with this set.The best bet is to find a new set,since the parts alone will exceed the cost of a new one.Pioneer or nec seem to be the most reliable that i have seen.
Jan 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Philips Magnavox 42MF521D/37 Television Logo
508 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
