Question about 2wire 1800HG Router (RG1800HG00)
Reconfigure as a WAP only
Can this router be configured as a WAP only using a cross over cable to get internet from another router
There is no wan port just a DSL phone line jack and 4 local eathernet ports and 1 usb port
Posted on Oct 15, 2008
  • 787 Answers
Do not use a cross over cable, use a normal cat5 patch cable connected from one of the lan ports on the other router to the wan port of this router.
Configure this router to obtain ip address automatically (like it would be configured to connect to a cable ISP)
Turn off DHCP on this device.
That should do it. If it does not, let me know because some router want a static route configured.
If you want 2 seperate networks with internet access, leave the dhcp on but change the internal address so that it is different from the other router.
ie: if the other router is 192.168.0.1, this one can be 192.168.x.1 (where x is anything but 0)
Posted on Oct 14, 2008
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
Linksys Wirelss Router-G problem
Hi. I would suggest that you chane the cross cable into a straight cable configuration, so that both router can transmit signal at the same time and might solve the issue of intermitent connection failure. Hope this Helps
Jun 04, 2010 | Linksys Wireless-G WRT54G Router
NEED TO CONFIGURE THE INTERNET SETTING,
To get your Glo 3G internet settings, you will send SMS activate to 444 using a 3G mobile phone. Save the internet settings in your mobile phone. To get Glo WAP settings, SMS your phone name and model to 927. e.g, to activate Nokia 2630, SMS Nokia 2630 to 927. Save the internet settings in your mobile phone.
Glo manual 3G/3.5G internet settings
Service name: Glo 3G
IP Address: 10.100.98.22
Port: 3130
Username: wap
Password: wap
Access point name (APN): glo3gvideo
Authentication: Normal
Home page: http://cms.gloworld.com
Jan 27, 2010 | Samsung Gravity SGH-T459 Cell Phone
Why link led of WAP54G Linksys is not blink if i install cable on LAN Notebook? i try reset this WAP but still not change. I can't login with IP 192.168.1.245. Thanks.
First RESET your router to defaults settings.Press RESET button for 10 seconds it is in back side of router.
Then connect your router to computer with ethernet cable then you can access it with default link http://192.168.1.1
or
http://192.168.0.1
Type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Then configure your router again set WAN settings as your interent service provider.
Enable DHCP if you want iip automatic from router.
CLcik on wireless and enable it .Configure your router as WEP or WAP then add code it is your password to connect internet.
Then save and restart router and computer.
Then connect internet.
Let me know if you need further assistance.
Dec 20, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I lose my internet connection when I plug the ethernet cable into the router
You need to configure/reconfigure you're Internet settings on the router.
For DSL, click this link.
For Cable, click this link.
Oct 25, 2009 | Linksys WRT160N Wireless Router
Panasonic cf-50 problems to connect wireless wpa personal
If the wireless card is an old model it possibly won't support WAP encryption. The wireless router most likely supports both WEP and WAP encryption.
WEP is not as secure as WAP so use the highest bit encryption that is available to you.
May 07, 2009 | Panasonic Toughbook 50 Notebook
Wireless
Have you configured the Belkin wireless router?
You need to configure the Belkin using a 10baseT network cable first before you configure the wireless card.
To make your wireless router secure you need to use your browser and type in the Belkin IP configuration address.
Then you need to change the Admin password, change SSID and turn off SSID broadcast, setup the encryption (use WAP or WAP2 if your wireless card supports WAP) and for added protection use MAC address filtering.
Apr 12, 2009 | Acer Computers & Internet
I have a dlink wireless router what do i do to reroute it
The CD is actually just a guide in configuring your router. You can still configure/use it even without the setup CD. If you need to reinstall/reconfigure your router, please provide the model number of the router and your Internet service provider (cable or DSL) so I can help you.
Aug 05, 2008 | Computers & Internet
Cannot connect my lap tp to the internet via my d link router on my desk top
Please indicate which is your issue.
Is your issue with the router's administrative password to used to configure the router?
Please confirm your router's manufacturer and model number.
IF not go to Wireless Configuration
If the router needs to be reset (because of an unknown password) do you know the proper settings to reconfigure the router? If not or even if unsure please provide your Internet Service Provider's name so we can get accurate instructions before proceeding any further on this password issue.
Is your issue with the passphrase/password for a wireless adapter to access a secured wireless network using either WEP or WAP encryption?
Do you have another wireless computer that works? -- you may be able to find the passphrase in the configuration of that machine's wireless adapter avoiding the need to have the administrators password for the router for the time being.
Dec 13, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
2wire 1800HG Router (RG1800HG00) Logo
69 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
