Question about Bose LifeStyle 5 Series-III CD Shelf System
Bose Lifestyle 5 Display
What capacitor did you choose ?? 100V or 250V with 33µF ??
You could send me an email v3by@yahoo.com
Thanks.
  • bose5 Oct 27, 2008
    My Bose Lifestyle 5 display does not work. Did someone verify what the correct capacitor and voltage is needed to fix it? where is the location of this capacitor?
5 Suggested Answers
althoffk
  • 4 Answers
SOURCE: Everything works with my bose
According to other threads this is due to a bad capacitor (either C19 or C16). It is a 33uF capacitor rated at 25V. Needs to be replaced by a 33uF higher voltage (like 63V). Have the same issue but have not yet completed the fix. Please perform a search on the forum and you will find it. It says is on the lower left side of the console pcb.
Posted on Dec 24, 2008
althoffk
  • 4 Answers
SOURCE: Bose Lifestyle
I have a service manual with complete pcb layouts and circuit diagrams, contact me in case someone is interested.
Posted on Jan 16, 2009
cjackHD
  • 71 Answers
SOURCE: Our Bose lifestyle 5 has no sound does the Bose CD
This can be repaired of it's later than a series 1. (not sure if the 1997 model was a series 1) Repair cost will be $225 plus tax (flat rate). Shipping is split between you and Bose. They give you a new 1 year warranty.
Otherwise, Bose can have you trade this in for about 25% off a new, current system.
-If this still powers up, make sure the small 1/8" portion of the input cable (plugged into "system control 1") is in good condition, because you may just need to replace that input cable for a no audio situation. If it's a different series, it will say "zone 1" I think.
In either case, you should call Bose tech support about this. (800-367-4008) Make sure you're with your system so they know what series of LS5 this is.
Posted on Jul 17, 2009
  • 10 Answers
SOURCE: Bose Lifestyle 38
They are tight with the files, I copied songs to new harddrive using nortons ghost, but when in installed harddrive back song looked to play as normal but with sound... Nearly but no luck.
Talking with service man, said its different format, i thought it was FAT32 (computer said) but service man said different.
Posted on Aug 20, 2009
SOURCE: Bose Lifestyle 5 speakers(woofer + 5 double cubes)
I repaired the contol unit per instructions from a post at FixYa.
Posted on Sep 12, 2009
Bose lifestyle 5. Display is erratic when playing cd or radio.
Change capacitor C19 (33uF 63v) next to the dispaly. This capacitor goes leaky over time, and causes ripple on the display which makes it dim or even dissapear completley. Also worth doing all the capacitors near to C19 while your there just in case.
changing C19 worked for me. Some people even up rate the capacitor to 100v, but 63v id the manufacturers reccomended.
Aug 23, 2010 | Audio Players & Recorders
I own a Bose Lifestyle 12 system and the display on the console has failed. All else works (ie: buttons and remote.) Is it possible to have it reasonably repaired, DIY or must I live with this as is? Thank...
Its working lifestyle 5, 8, 10, 12 receivers Its Easy fix you need open it up and on lover left corner on bottom first capacitor value 3.3uF needs to be replaced.I did all ready 3 units and its all work now
Oct 28, 2009 | Bose Lifestyle 12 System
No LED Display On The Bose Lifestyle Model 5 Music Center
Hi, you have to replace the 100uf capacitors c14 c15 c16 c17 and c19 on the digital board, that will cure your LED fad problem.
Chris.
Jun 25, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle System 12-no lights in display-TV sound doesn't wo
There is a service available at www.AnyoneCanFixIt.com where you can send it to fix the display. Quick service and way cheaper than Bose.
Apr 01, 2009 | Bose Lifestyle 12 System
Everything works with my bose lifestyle model 5 music center but the display wont light up. Do I have a bulb out or something ? How can I fix this, its driving me nuts! Thanks for any help you can give....
Dec 20, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 5 ~ dead display fix
Hi the fix for a dead display is a faulty capacitor. Depending upon which board version you have, you need to replace the 33 uF / 63 volt capaitor. On some units this is C19 on the display board, on other units this capacitor is mounted on the main board and re-numbered, there is only one 33 uF on the unit so you should be able to find it.
Dave
Sep 21, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 38
I believe there is a USB port on the back of the unit. Has anyone been able to connect to it? Can anything be seen of the files on the hard drive?
Aug 10, 2008 | Bose Lifestyle 48 System
Bose Lifestyle 8 no display
I had the same problem and Mark Burgess at http://forum.ecoustics.com/bbs/messages/1/125990.htm helped me out, change the 4 capacitors in the lower board, lower left side and that will solve the issue.
regards
-Luis Carballo
Nov 20, 2007 | Bose Lifestyle 8 series II System
Horiz. lines across top of screen.
I agree with solution #2
I recently had my phillips 27" model 27PT6341/07 repaired after warranty expired due to white lines appearing at the top of the screen. The shop advised that it was a capacitor giving me the problem. So, after getting it back, I examined the repair job and the shop had replaced a capacitor at the back of the main board, next to the rear rca inputs. It is labeled 10uf 100v. I was told that it would fail again soon because it is a manufactures defect. For me it is at location 2465. Here are a couple of photos of the part.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
Good luck,
Ed
Nov 13, 2007 | Philips 27PT6441 27" TV
Bose LifeStyle 5 Series-III CD Shelf System Logo
294 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
