Question about Hyundai ImageQuest Q15 15.1" Flat Panel LCD Monitor
Monitor shows screen then goes black
Screen shows correct image then goes black. if monitor switched off then on proper screen shows for a second then black again. have checked all connections and seem ok
  • x1000delta May 24, 2009
    "screen shows correct image then goes black. if monitor switched off
    all connections and seem ok."
    I have the same problem, checked all the pins, no problem,cable is ok, you can see the immage on the screen, but the screen does not light up.
    Guru:
  • 558 Answers
It is the Monitor Cable connected to the CPU cabinet is faulty. Please check out the cable and its pin firmly.
Try to find the fault, may be the cable broken or tear up.
Let me know if further diagnose required.
Have a nice day.
Ellin
Posted on Oct 14, 2008
Lg2284 screen goes to black in a second
There is a circuit board that is failing. Sorry but it is time to buy a new monitor. If you are skilled at electronics repair you can replace the circuit board, but I have found that the price of the circuit board plut the effort of replacing it is not worth the trouble.
Feb 23, 2015 | Computers & Internet
My monitor shows image for about 3 seconds then goes black.
sounds like its set in the bios to boot on a second video card. At startup hit f2 (usually) then find the first boot setting and make sure its booting to the correct card. I
May 08, 2011 | Princeton Digital Computers & Internet
problem related to lcd lamp supply
just replace the power supply(called inverter board) connected to the lcd panel lamp
Jan 21, 2011 | Hyundai ImageQuest Q15 15.1" Flat Panel...
The screen shows image for like 3 seconds then goes black but the screen is still on
-you can check the cables on the monitor have it disconnected and reconnected
-if it still does it try another monitor cable
-one way you can check is to use a flash light by shining it on the screen and look closely to see if you can see any images .
-try touching the menu screen on remote to see if you can see image, if you can then the lcd screen is bad and would need to be replaced. the same would be if you cant see any image =
Nov 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Screen goes black on my hp pavilion dv4000 notebook
Try connecting an external monitor to the laptop, power up the monitor first then boot up the laptop. The video data will switch to the monitor automatically, check if the monitor dislays a normal image and see if the image stays on the monitor.
Also press and hold the Fn key and press the F4 key, these keys toggle the video output between the LCD screen and the video port.
Test to see if this functions correctly.
Get back to me with the results of the tests.
Jun 03, 2009 | HP Pavilion dv4000 Notebook
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Image appears for 2-3 seconds then screen goes black
The following steps are how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Mar 15, 2008 | IBM ThinkVision L170m (Black) Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Hyundai ImageQuest Q15 15.1" Flat Panel LCD Monitor Logo
462 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
