Question about Hitachi 37HDL52 32 in. LCD Television
MASTER RESET HITACHI L32H01U
HI I HAVE MOVED HOUSE AND CAN NOT RETUNE TV TO DIGITAL WITH OUT THE PIP SCREEN OR PAP SCRENN WITH THESES 2 TURNED OFF ALL I GET IS SOUND BUT NO PICTURE IS THERE A MASTER RESET SEQUENCE?
premtech
  • 934 Answers
SOURCE: My new Hitachi LCD L32H01U
If you know just a little about electronics I can suggest several things. If not you'll need a tech...
Forst check F901 in the power supply, if it's open replace it and D902. If not open, check R964 for broken solder connections. The power supply in this unit is very commonly the culprit of a dead unit as you're describing... It's not usually an expensive repair for a qualified shop if any of this sounds a bit beyond you...
Take care Juliet and let me know how it turns out.
Bill
Posted on Nov 22, 2007
  • 6 Answers
SOURCE: TV Problem
NO IT HASNOT .. IT SOUNDS LIKE YOUR EPROM
Posted on Feb 15, 2008
Fujitsu
  • 29 Answers
SOURCE: hitachi tv please help
I write the same in other consult
Posted on Nov 28, 2008
SOURCE: we have a Hitachi 42hds69
Here is what you need to do to fix this. Call Hitachi Global Storage Technologies & request for the firmware upgrade.
1-800-HITACHI (448-2244)
They will send it to you for free. You get a small SD card that plugs into the back of your TV just below the Cable Card Slot. I wouldn'd have known it was there unless the instructions in the mail packet told me so.
To determine if you need to upgrade go Into the Setup Menu. Then, Go to Software Upgrades & look at the software version. I had 0110.xxxx. the version I upgraded to was 0125.0000 & it fixed the audio problem on 7-1 & 11-1.
now all channels work great.
THANKS HITACHI!!!
Posted on Apr 12, 2009
  • 1039 Answers
SOURCE: Hitachi plasma screen black. blue light on... no picture though.
Replace digital board. Common for this set.
Posted on Nov 09, 2009
How to retune freeview tv
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 07, 2014 | Sony BRAVIA Televison & Video
Hi, I have an alba lcd32880hdf tv and moved tv to different part of room, when I turned the tv back on and did auto tune channels came back up except itv ones so went to retune again but tv then came up as...
The Tv is working fine, from the description it is that one channel not coming in, the blue screen indicates no signal. It could be that the signal in that room is a little weaker and just going below the thresh hold to allow it to come through. It is possible the station might have been off the air, try another auto tune.
Apr 08, 2012 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
No sound...We moved the TV from one place to another and lost our sound... I have a multiviewer 4 dual tuner PIP
Try to check the cables specially the input, output of your digital receiver specially the audio cable. Good day and best regards.
Aug 07, 2011 | Hitachi Televison & Video
Trying to retune Samsung LCD TV LE26R7 but settings (4th option on menu) is greyed out and won't let me access to retune was okay before sept 30th
HI,this might just help!...
1.press D.MENU on youre tv remote
2.scroll down to SYSTEM
3.access the RESET function
4 enter 0000
5 follow on screen instructions
TV will then wipe all existing channels and start from scratch.
worked a treat on my SAMSUNG LE26R7........However i noticed my signal strength dropped significantly!!...obviously them at the other end (digital tv boffins)have been mucking about,A bit of fiddling about with my existing arial did the trick!!
REGARDS.......G WATSON
Oct 02, 2009 | Samsung Televison & Video
How do i reset a HITACHI AX-M131U DAB/FM/CD/USB/MP3 MICRO HI-FI SYSTEM i want to retune it
push the funtion button till dab bomes up on the screen then push in the info button and it will start to retune dab. for a total reset just push the select button 1 second after you hold the info button for 5 seconds
Mar 09, 2008 | Audio Players & Recorders
Colors overlap on left third of screen!
Yes it is convergence, but the first things to think about are. Did the set get bumped when you moved it? If so likely one of the guns is out of alignment physically due to jarring. However the other next best thing to look at, is if the set is near any type of magnetic object, mainly like a stereo speaker (larger ones) so if that is true, try moving it away slowly while the set is playing to see if it clears up. Lastly that the screnn itself is off or broken again a physical problem to resolve.
Jul 08, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 37HDL52 32 in. LCD Television Logo
219 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
