Question about Refrigerators
Compressor running, I can hear the fan but only blowing warm air
We had a Kenmore refrigerator (model # 253.7188210A, manufacture date 09-02) given to us when ours went out. When plugged in I can hear the compressor and the fan blowing, but only warm air blows in the top freezer compartment and the fridge part. Also when you touch the back of the fridge, I got shocked (don't touch the back, right? hahaha). Anyway, is there any hope for fixing it without spending a fortune? Getting tired of using a cooler :(
Thanks
  • Kellie P
    Kellie P Oct 16, 2008
    Thank you. I knew it couldn't be a simple cheap fix. I appreciate your quick response :)
  • 120 Answers
Not realy if compressor is running you are sure of that and condenser motor is running as well the open the evapoartor are if no frost then there is a leak or restriction best bet call a tech to make sure but it looks like etheir case it will be more then 200 dollars new fridege 450 to 500 balance out or you can call sears buy the service smart agreement for 300 dollars and they will fix it
Posted on Oct 15, 2008
Maytag fridge not cooling
If the ref or freezer is too warm and you turn the dial to make it colder the compressor should come on. If the ref or freezer is not cold like you say the compressor should be on all the time. You should hear it, but you can definitely feel it and it should be very warm after a short while.
If the compressor does not get warm unplug the ref with the compressor running and plug it back in immediately. A good compressor should not start up right away.
If it is running and not getting warm and does start right up after unplugging it and plugging it back in it is inefficient and not compressing the freon gas enough and therefore not cooling enough.
The fan in the freezer should be running as should the fan under the refrigerator.
The condenser should be warm and the fan should be blowing[drawing] air across it when the compressor is on.
You don\'t repair compressors and to recharge them correctly is expensive.
May 01, 2013 | Refrigerators
My Kenmore side by side refrigeratro model #50593003 went out. The fan blows cool air, not cold, the freezer doesnt work nor does the refrigerator side. What do I do?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Refrigerators
My Kenmore upright freezer is not working properly. Model: 253.9208212 Freezer still has power to it and the fan is still blowing cold air around but the freezer is nowhere near as cold as it should...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 11, 2010 | Kenmore Freezers
My air is 82 inside but the unit outside is blowing a cool air instead of hot/warm like our neighbors.
If the unit is not blowing warm/hot air then either your compressor isn't working or your refrigerant charge is low. Make ure that the compressor is running. If you can't hear it over the fan you can disconnect a fan lead and then see if you hear it. If it's not running then verify that it has power to it then check the capacitor. If you don't have a meter to check it with then you can take it to a heating and air supply to get it checked. Replace it if necessary. If the capacitor is good then check the compressor windings for continuity using and ohmmeter. If the compressor is running then get the refrigerant charge checked.
Aug 29, 2010 | Heating & Cooling
Central air conditioning blowing out hot, not
Can you tell if your outside unit is running (the fan and compressor)? Sometimes it is hard to hear the compressor for the fan. If they are running then you possibly have a low refrigerant charge and need to have some added. Refrigerant pressures and temps can be checked to verify this. If they are not running then you need to find out why. If both the fan and compressor are not running then first make sure all the breakers and disconnects are closed. Then a bad contactor or capacitor could be the problem. If its just the compressor that's not running then it could still be the capacitor or maybe the compressor.
Apr 29, 2010 | Heating & Cooling
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
Inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Dec 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 106.72102100 Not cooling URGENT!
behind the back panel that you pulled off is where the compressor is. on the left side of the compressor is where the relay/overload is plugged in. its gone bad. if you touch the compressor it will either be really really hot or room temp. unplug it let the compressor cool and replace the relay/overload to fix your problem
Nov 27, 2007 | Kenmore 65812
Kenmore upright freezer.
Will need a little more information to assist you with answers. Will need the model number if available for you Kenmore and will usually be on inside Freezer/refrigerator door and near bottom. Will look like model #363.1234567 for example.
Now if it's not cooling at all, is the compressor running beneath the fridge? Is the condenser fan running that is below the freezer and near the compressor? Is the evaporator fan blowing air in the freezer section? Do you hear clicking noises in the compressor area and can you feel the compressor to see if you feel warm or hot to touch around its side and top? Can you tell me of any other things that you noticed before the refrigerator stopped working? Is the temp control digital or manual settings? Has the settings been changed since you turned the refrigerator off and then back on? Thanks, Sea Breeze
Oct 28, 2007 | Freezers
Refrigerators Logo
239 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
