Question about Epson AcuLaser C900 Printer
Error 6022 Thanks for your advice but the problem is not yet solved. As I said, I've already checked the photoconductor before posting my problem and I don't see any foreign material on it. Now it's worse, I'm getting an error 6022. Previous posting: There is a rectangular mark (the size of an address label) on each pageI'm printing. Before that, I did print some self-adhesive addresslabels. My hunch is that a label is possibly stuck somewhere in theprinter. I called Epson and they told me to check the photoconductorand transfer unit but I didn't find anything there. I followed all thepaper jam instructions but still no luck. Do you have any idea how Ican solve this problem? Thanks so much for your valuable assistance!
I had the same problem just today, i disaasembled the printer got out the transfer built and cleaned it, unscrewed the speed sensor and cleaned it , and its now working perfectly again,.
Posted on Nov 09, 2008
Our printer is saying it has stopped because the photoconductor kit has reached the end of its useful life.
You need to replace. It is also called the drum unit.
http://www.nextag.com/dell-1720-photoconductor/shop-html
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 19, 2011 | Dell 1720dn Laser Printer
The second light keeps blinking and i have already replaced the photoconductor kit..
After replacing the photoconductor kit, you will need to reset the photoconductor page count. You can follow the instructions found on this link to reset the page count: http://bit.ly/9Voy5I or simply press and hold the CANCEL button while the printer is on and the front door cover is open. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 26, 2010 | Lexmark E330 Laser Printer
How do you remove the old Lexmark E232 photoconductor and install the new Lexmark E232 photoconductor?
Hello. I hope you got it working already. If not, here's a link to the Lexmark website to guide you on how to install/replace the Lexmark E232 photoconductor. Just click on this link: http://bit.ly/cWGimB. Don't ignore WARNING, NOTE, and IMPORTANT. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 23, 2010 | Lexmark E232 Laser Printer
We have message to Replace Photocondutor. Is that toner? If not, s it self-install or do we call for Tech?
Most photoconductor assemblies are what they call "CRUs". That means that they are Customer Replaceable Units.
Check with the Ricoh web site "Support" to verify the installation process and order the part.
Don
Nov 19, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I swapped Photoconductors from 2 other 1710's; no go. Reset?
Problem
Dell 1700 printer prints out a page announcing that “the photoconductor has reached its useable life and it needs to be replaced for a new one”. You replace the photoconductor for a new one and the error light is still blinking and the printer keeps on printing the above mentioned page.
Solution
Steps to Reset the Photoconductor:
  1. Power off printer
  2. Open the front cover.
  3. Press the continue button; while pressing the continue button power on the printer and wait (still pressing the continue button) until the error led is solid, then release the continue button.
  4. Close the front door, all light should be solid.
  5. Wait until POST finishes.
  6. Press the Cancel button 4 times slowly, the toner led should be solid.
  7. Press the Continue button until all lights go up and down, then release; the Toner Low led is solid.
  8. Power off printer and then back on.
  9. Press continue button once, print a test page.
  10. Check the information about the photoconductor in test page, it should display an OK status.
Note: if these steps don’t work for the first time repeat three times. If still the steps don’t work, the printer needs to be replaced for a new one.
Jun 26, 2009 | Dell 1700n Laser Printer
Is my Dell 1700 Laser Printer photoconductor drum truly fried?
The drum collects used toner for apprx. 30,000 pages. After that, the printer recommends that it be changed to prevent used toner from spilling internally into the printer's mechanisms. The whole photoconducter/drum can be replaced. The new part from Dell is apprx. $50.00 US.
http://accessories.us.dell.com/sna/products/Printer_Accessories/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=310-8710#Overview
You might have reset the "counter" for the photoconducter. Ever  have a water  fillter with an electronic timer? You replace the filter, then you reset the timer? Perhaps you reset the timer without actually replacing the filter. So to speak. :)
The question you should ask yourself is: would I like to spend $30 - $60 [it's cheaper for refurbished parts- Google it] replacing the drum head on a 7 year old printer, or would I rather invest that in a new printer?
Feb 23, 2009 | Dell 1700n Laser Printer
SC366 on CL4000DN
I just came across this post, you've likely solved it by now; However it is a "Toner density" error related to your cyan photoconductor. It is a defective connector. Replacing the cyan photoconductor should solve problem.
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
Photoconductor and error 537
Perhaps a copy of the parts diagram and/or the multi part service manual might be of more help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 14, 2008 | Epson Aculaser C1100 Printer
Worn Photoconductor Epson C1900 laser Printer
hi this solution has already been covered in full lengths. Epson c900 and c1900 are similar. have a look at my posting on this. photoconductor reseting by Labatt in this forum. read from the start.
http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
Jan 29, 2008 | Epson AcuLaser C900 Printer
84 Replace photoconductor
i have just change drum but it was show" 84 replate photocontructor". Pls help me solve this problem.
Dec 27, 2007 | Lexmark X340n All-In-One Laser Printer
Epson AcuLaser C900 Printer Logo
424 people viewed this question
Top Epson Office Equipment & Supplies Experts
Michel Smith
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
