I have an OCE CS4035 large format color scanner, and I always get an error 'the stitching of camera b has failed'. What is the solution?
  • 3 Answers
SOURCE: I have an OCE Scanner
There could be a scratch on the white back ground / still remaining durt that is hard to clean. Open the lid and clean it's white background with a soft cloth. If the contamination is persistent, clean with a moist cloth and little soap. Then make sure to dry it with a soft dry cloth before closing the lid. Also clean both sides of the glass platen. Normally dry. When cleaned wet make sure no stripes remain on the glass platen. You can clean bottom side by lifting the glass platen on the back side. Then run the maintenance software. Should be installed on the PC where the scanner has been attached to. It will ask for the scanner calibration sheet (delivered with scanner). Do as aked by the program and the scanner should fine again.
Another possibility is Erase Parameter Blocks: Can be started from scanner maintenance program: Right click in the title bar and select Erase Parameter Blocks. Follow the instructions. Finally you need to recalibrate the scanner. The scanner maintenance program will instruct you to do so.
How old is the lamp? Sometimes I have to plug the scanner into a UPS (uninterrupted power supply) to fix a similar issue. Hope this helps.
Posted on Sep 05, 2011
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Oce scanner Error 10516-247
my oce TDS450 scanner has the 10516-247 error. Please help me
Nov 16, 2013 | Office Equipment & Supplies
Oce tcs500 scanner - error code 10514-246 scan failed. any solution for fix?
Repair of oce scanner with error code 10514-246:
The customer Service said that this error means there is not enough light reaching the camera and we have to let them replace the lamps. cost:1500€ :(
solution: i removed the backplate of the scanner (3 screws) and cleaned the lower mirror. it was that dirty that i nearly didnt find it. it is placed on the groud of the lower big hole behind the backplate.
After that i recalibrated the scanner and now it works fine again.
I hope this helps since there is no correct exlanation of this error on the web.
Nov 01, 2013 | Office Equipment & Supplies
My Oce Scanner has the 10514-246 error. Please help me !
my oce tcs500 error code 10514-246 start of scan failed
Sep 07, 2011 | Office Equipment & Supplies
I have an OCE Scanner CS4154 which is typically only used a few times a year. When it's being used, the scanner reports the following message: 100-32145 - Stitching between Camera B and C failed....
Aug 29, 2011 | Office Equipment & Supplies
My oce 4780 scanner has a problem, it warms up ok then I scan a couple of maps then the maintenance and clock light come on. If I turn off and on it will eventually go away, but the help on the oce scanner...
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Mar 14, 2011 | Computers & Internet
Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Oct 09, 2009 | OCE Office Equipment & Supplies
Camera B error for crystal XL 40
You are right, it is very likely!. These type of scanners either use multiple cameras or use multiple mirrors to break a segment into a focussable area and do electronic stitching. (Electronic stitching is another painful area, the scanner has to 'create' a true image removing duplicate pixels). Also with Lens there is focal length aberration. Please note even the brochure carries the statement, "Torsion stabilised" suggesting that it is succeptible for misalignment. The mirrors are kept in position by rubber pads and tiny springs, but rubber pads being sensitive atmospheric variations, there can be focussing issues. Unfortunately you cant even kick the scanner accidentally or on purpose!
S. Mohan
Nov 15, 2008 | Contex Scanning Technology Contex...
I need a scanner that will scan 10X14 pictures
I found some scanners for you listed below but,
You can also scan large pictures in sections, and then use a program like STITCHES. Basically you scan it in quarter sections and then create a working board in your photo program and then you copy and paste each section into that board and line up the edges.
This is what most people do rather than buy a very expensive large format scanner.
Some large companies also have large scanners for maps etc. If you know someone who works for a very large company or one that does surveying etc. They may do this favor for you.
Though copy stores may have the size you need, copywrite issues will be asked about.
Here is the list.
large format scanners http://www.microtekusa.com/lf.html
Microtek ScanMaker 9800XL Scanner
Price: $1,038.31, 12-by-17-inch tabloid size bed
Mustek Scan Express A3 1200 Pro USB Large Format Scanner
$154.69media_size_maximum: A3 (11.7 in x 16.5 in)
http://www.contex.com/english/scanners/sd_series_scanners.aspx
Maximum Scan Width 44in.
http://www.xerox.com/digital-printing/large-format-printers/large-format-scanners/enus.html
Input Size:Min: 4.5" x 5.5" Max: 42" x 100'
Thank you and good luck.
Oct 25, 2008 | HP Computers & Internet
126 people viewed this question
k24674
