Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Samsung Tantus 119cm 100Hz Rear Projection Problem
3 Years old - Picture changed to blurred, jumping, distinctly very green and red - Received a comment that it may be a "globe" and another, that I may as well place the television on a dump. Please advise????
I have a samsung hdtv and direct tv is attached to it. and i can't get a better picture than 480 i when the tv is capable of 1080i. ? when i change the cable box higher its just blurry. what do i do?
Posted on Nov 18, 2008
SOURCE:
Samsung tantus blinking red light
you need to general service the whole unit. this will include re-soldering and changing some defective components from the board, which has been damaged through using from past years. my advice is to have a quotation from service tech and then think about repairing it..if it is better to buy a new one..
Nov 16, 2009 | Samsung PCH521R 52" Rear Projection...
Hello tv has warped bottom and top screen on a rear projector samsung and blurred vision with red,green blue colurs not aligned tried to tune to no avail Samsung rear projector tantus sp42w4/42w5
The colors tell me of a convergence IC issue, warped bottom and top tell of another.
see this page on reparing the convergence problem yourself
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
also compair the before and after pictures to see if this is the other problem your having.
Then you have another fault, which im not completely sure of right now. I will look into it.
Oct 27, 2008 | Televison & Video
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
May 11, 2009 | Televison & Video
Picture turns to red & green and becomes blurred.
This is likely solder connections cracking on your convergence ICs. If you can bump the tv and it goes back to normal, it just needs resoldering, but if it doesn't, then it needs the ICs replaced. If the convergence is out, you will see a bowed picture and the red, green, and blue will be separated. Worth repairing if you can find a company to do it affordably, I can help you repair yourself if you have disassembly and soldering skills.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Samsung Tantus problem
your main power supply is gone out
Aug 30, 2008 | Samsung PCH521R 52" Rear Projection...
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
Samsung tantus 1080i
hi i have a 47" samsumg tantus tv and i haven problem with the screen. has some red lines
Feb 17, 2008 | Hitachi 57F500 57" Rear Projection...
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jan 11, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung rear projection 42" green curves causing distortion just started
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Red line fault
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 07, 2007 | Samsung HCN4226W 42" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
268 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
