Question about Denon AVR-3806 Receiver
MID-RANGE DISTORTION 2 YEARS AGO, I PURCHASED A DENON AVR-3806 RECEIVER, KLIPSCH SURROUND SPEAKERS, KLIPSCH SUB WOOFER AND KLIPSCH LA SCALA II FRONT SPEAKERS. BJORN'S OF SAN ANTONIO INSTALLED THE SYSTEM AND EVEN MADE A SECOND TRIP TO TRY TO RESOVE THE DISTORTION PROBLEM BUT NEVER COULD GET RID OF IT. OF COURSE, I 'VE USED THE AUDYSSEY EQ AND I'VE TRIED EVERY COMBINATION POSSIBLE BUT THERE IS ALWAYS THAT LITTLE "GHOST" MID-RANGE DISTORTION. WOULD IT BE BETTER TO GO A HIGH END INTEGRATED AMPLIFIER??? I COULD CARE LESS FOR THE AUDIO VISUAL SIDES. I JUST WANT A GOOD STEREO SOUND. JOHN HOOVER - whatever410@verizon.net 325-392-2913
  • 71 Answers
Hi it is an amp module failure inside £129.00 plus vat 4 hours to replace total strip out £380.00 total to do these are made by samsung and rebadged horrible things dump it thats my advice regards kirk
Posted on Dec 09, 2008
Setup help for record player (Pro-Ject Carbon Debut) and pre-amp (ART DJPRE II) into Denon AVR-1909. I have everything setup properly, but I cannot get the subwoofer to turn on with my 2-channel settings...
In two channel mode, there will be no subwoofer signal unless you change the front speakers to 'small'. If you set the front speakers as 'large' then the full frequency spectrum will be sent to the front speakers, and none to the sub. Switching from bluray may keep the surround configuration until you restart as you mentioned.
Sep 26, 2013 | Denon AVR-1909 Receiver
I recently purchased a new Denon AVR-391 receiver and am having a problem hooking up my subwoofer. It seems that the Denon has a pre-out RCA looking output and my subwoofer uses conventional speaker wire. ...
Your sub-woofer apparently does not have an amplifier built into it. This type requires you to use your front left and front right speaker output to got through it to your regular speakers. It is called a passive sub-woofer for that reason.
To set it up, Connect your front speakers to the "output" of the sub. It should say "to speakers" on it.
Then connect the Speaker Outputs for the left front and right front on your Denon AVR-391 directly to the Sub. It should say on the back of the Sub "to amplifier".
Here is some theory you should know, if you don't already know it, that will help you get a satisfactory result in setting up this system.
There is a condition on setting up all speakers and subs that not everyone know. It's call "phase alignment". Phase alignment (A Good Thing) refers to all of the speakers in a system moving in the same direction (in and out) at the same instant in time. This gives you much clearer sound and better response from your sub-woofer.
Phase Cancellation (a bad thing) is when some of the speakers are moving out and other moving in during the very same instant in time. It causes problems in sound.
IN A SUB-WOOFER, IT CAN CANCEL OUT THE LOW NOTES.
Here is how to handle it:
On the back of the receiver the speaker terminal outputs are colored Red and Black. Black is considered negative and Red is considered positive. On the back of the Sub woofer and on the speakers the same colors apply. MAKE SURE THAT ALL OF THE CONNECTIONS GO BLACK TO BLACK AND RED TO RED WHEN CONNECTING UP THE SPEAKER WIRES.
The system will work either way. But you will have severe bass loss if the woofer wiring is out of phase because of phase cancellation.
Hope this helps,
Best Regards,
Mark
"Phase Cancellation"
Jan 05, 2011 | Audio Players & Recorders
Cant get klipsch sub woofer to work. do is there a menu setting through receiver to do this?
What model is the sub? Is your Klipsch sub powered? If it's already plugged in and powered on make sure you have the RCA cable going to the correct LFE output on the Denon and have it set to 5.1.
Jan 03, 2011 | Denon AVR-1601 Receiver
No signal coming from sub woofer out
set the front speaker to small or if still set in large,set the subwoofer setting to lfe+main.
Feb 18, 2010 | Denon AVR-1708 Receiver
I just received a Denon AVR-4308ci receiver. I have two passive subs in my system. The receiver only has one powered output. Since I am not using the surround back speaker outputs can I use these for the...
Sure, if you want to hear Surround Back program material coming from the subs without midrange or tweeters. (Sarcastic) Of course, the LFE program material will still be going into a black hole somewhere.
Run the subs in series with each other -
Sub Amp negative to 1st speaker negative;
1st speaker positive to 2nd speaker negative;
2nd speaker positive to amp positive.
Run the speaker level adjustments routine and enjoy.
Just for giggles, try what you were thinking about. You won't hear much from the sub(s) unless you programmed the Surround Back channel as full-range and then have something like the Apollo 13 launch for program material. Normal audio won't send much low-frequency material to those channels. The optimal place for subs is on the LFE or sub channel.
Nov 17, 2009 | Denon AVR-1507 Receiver
MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
Apr 10, 2009 | Onkyo TX-SR875 Receiver
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
AVR 810 Denon Receiver Sub Woofer Hookup?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Dec 28, 2007 | Denon AVR-2106 Receiver
B Speakers: Rear A Speakers and Sub stay on
First, check you wiring. Have you tried to turn off all speakers then turn on only the "B" set?
Might also be your "surround" settings. Try a "2" channel mode if available.
GL!
Aug 09, 2006 | Denon AVR-1604 Receiver
Denon AVR-3806 Receiver Logo
181 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
