Question about Concept DDM-200 Car DVD Player
Concept dvd 168 C can i use it in europe - PAL system ?
I d like to know if i can use this palyer with european dvd, is it multisystem or only NTSC ?
    Genius:
  • 1,605 Answers
Not just the format, the voltage difference. you need a converter for the power. my suggestion is to buy one in Europe insteand of bring one from here, you only asking for trouble.
Posted on Oct 14, 2008
Would this player be able to play region 1 and 2 discs? Some of the Classical DVD's I would like to order also requires an NTSC (American compatable TV.) Would it work on my new flat screen Samsung?
Answer is... NO, not unless your TV is a multisystem and the DVD player is also Multi-system too. Some PAL/SECAM DVD allow NTSC playback, but will not allow recording through the line in connection EVEN to a NTSC compatible TV. Best to keep your system fully multisystem if you intend of doing this routinely.
May 29, 2015 | Samsung BD-F5100 - Blu-ray disc player
Why does my DVD player only play in black and white?
hi, make sure that you are playing the correct color system disk they are disk recorded in a standard NTSC disk if you are living in US or PAL SECAM from arab country.same with your DVD player check if your player supports a multisystem disk...You can also try to switch the color system from your remote control you switch from NTSC to PAL system...
Apr 06, 2012 | Memorex Televison & Video
How make my dvd player play movies in color
Dear Laysia,
Maybe your DVD player and your TV are not set for the same TV transmission system. The TV system in U.S. is NTSC. TV systems in some countries in South America and Europe are of the PAL type. You have to check in the manual for your DVD and your TV which TV systems they work with . many of them are multisystem, but you have to check in their menu or settings if BOTH are set to AUTO or to the same TV transmission system.
Hope it helps!
Best regards,
Miguel Luiz Martins
Dec 28, 2011 | Kenwood DV-605 Multi-disc DVD Player
When you insert a dvd it says PAL DISK
PAL is the format of the dvd and there are two main formats for a dvd and they are PAL or NTSC. The NTSC format is mostly used for the United States, and the PAL format is used more in Europe and Asia. An older dvd player will have the format options in the setup menu for the dvd player, and from the setup menu on the tv screen the dvd player can be set to play the PAL dvd's. However if that is not the problem and the dvd player no longer can tell a PAL from a NTSC format then the dvd player either needs a serious lens cleaning or it has a malfunction. Also, the back of the cover for the dvd should say if it is PAL or NTSC.
Jun 16, 2010 | JVC TH-A9 System
I bought pioneer muti system dvd
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Mar 04, 2010 | Samsung DVD-V90K Multisystem DVD/VCR
Plays movies in black and white? not in color!
it has something to do with your TV's video system and your player's video system...they should match...that is,PAL-PAL,NTSC-NTSC and etc..or if your tv has a multisystem then just set it to AUTO. Check on the dvd menu for the video format maybe that´s the problem , hope this helps , AJ
Jul 07, 2009 | GPX D108S DVD Player
I just hooked up my DVD player (Panasonic DVD-RP82) to my television. I have audio and visual now, but I the colour is in black and white. How do I fix this? i have tried many combos of plug ins. Thanks.
it has something to do with your TV's video system and your player's video system...they should match...that is,PAL-PAL,NTSC-NTSC and etc..or if your tv has a multisystem then just set it to AUTO..
Jun 18, 2009 | Panasonic DVD-RP82 DVD Player
Coby dvd player 536 only plays movies in black and white
Jun 15, 2009 | Coby DVD-536
No color when playing DVD
your player is set to the wrong format ie either ntsc if your in europe or pal if your in america, you need to go to the setup and make sure the dvd setup is for your region. pal in europe,ntsc in america..most dvd players automatically switch.but sometimes people change the settings without knowing.
Jul 01, 2007 | Bose Lifestyle 38 System
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Concept DDM-200 Car DVD Player Logo
87 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
