Question about HP Officejet 4110 All-In-One InkJet Printer
My printer does not print anymore...
....while it has enough paper in the keep saying out of paper....and it sounds like it keeps rolling and rolling without any result.
  • AlmsForThePo Dec 30, 2008
    I have the same problem. I can feed the paper in manually by pushing it it ever so slightly when the roller tries to grab it and it usually works but I have to do it for every page and it's a HUGE pain in the ***. The roller is grabbing the paper and I can't figure out how to open the printer to clean the roller. Anyone know how to do this?
    I'm not even sure this is the problem. Maybe the device isn't clamping on the paper hard enough or something.
    Can anyone help?
  • 352 Answers
Hi Ika1s, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
Posted on Oct 14, 2008
Keeps saying load paper, paper is in
Are the rollers worn out? If they have a slick appearance, that is your problem. Also examine the tray and see if it is lifting properly.
Sep 30, 2017 | HP Photosmart 3310 All-In-One InkJet...
Paper want go in to print
The reason why it keeps saying this is cuz you paper feed tire needs replacing. Now i am not sure based on the cost of this unit if it would be worth to have this repaired but, this is what is causing this error.
Jul 24, 2009 | Lexmark X7170 All-In-One InkJet Printer
Paper alarm; printer keeps printing same job
remove all supply and then plug then attach data cable, uninstall printer driver and install again
Jun 18, 2009 | Canon MF8180C Color Laser MFC Printer
I have a lanier 5265 keeps saying paper misfeed
Hello sir; The paper stuck in your paper tray ,I believe in first tray, pull out tray you will find out.
May 02, 2009 | Lanier 1205 Copier
My printer c5280 keeps saying please reinsert or lower photo tray
If it is asking for photo paper you should be able to hit ok on the screen and then it should go to the default screen and be ready to print.
Jan 17, 2009 | HP Photosmart C5280 Printer
Easyshare 500 printer
Be sure the paper tray is full.  Though not a satisfactory solution, I've found the little steel tab that lifts the paper up to be grabbed by the roller just doesn't lift it far enough.  I keep the paper tray full.  Now I only have the problem if I let the tray get down to only one or two sheets.
Dec 11, 2008 | Kodak EasyShare Photo Printer 500
Paper too thick?
You will need to use the manual feed and insert the cardstock one page at a time. First look at the rear of the printer for a purple dial. Roll the dial downward. This will allow the printer to exit straight out the back of the machine. Allow enough room at the rear of the printer so the cardstock doesn't hit anything on the way out. Next look at the front of the machine at the **** just above the paper tray. You'll see an envelope icon. Align the cardstock when manual feeding one sheet at a time to the left side of the **** next to the envelope icon. When you hit "file, print" select MANUAL FEED in the print window.
The 4L will only do cardstock by one at a time in the way noted above as the feed system isn't strong enough to make the sharp bend coming out of the tray or in the back to bend it around and into the top tray.
Sep 22, 2008 | HP LaserJet 4L Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
Printer Won't Take Paper
I beleive that machine has two slots to put paper, try moving the tray to the other slot, for some reason it may have defaulted to that tray.
Nov 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 4110 All-In-One InkJet Printer Logo
Ben Johnson
