Question about Sony Walkman NWZ-B105F MP3 Player
It has frozen on the options screen where you can choose music/radio etc
After removing it from the usb drive it froze on this screen.
No buttons work.... The PC does not recognize it when it is inserted in the usb
Simply by pressing the reset button fixed the 'freezing issue'
Posted on Oct 18, 2008
HTC Wildfire touch screen frozen
You can try 2 things:
    1)Soft reset - clears memory and restarts program
    2)Hard reset - deletes all saved data and settings
    Soft reset
      -Locate reset button to right of USB port on bottom of phone
      -Press reset button with stylus
      -Wait
      Hard reset
        -Press and hold both talk and end buttons
        -Press reset button with stylus while holding talk and end buttons.
        -Release talk and end buttons and press enter
How to Troubleshoot Frozen HTC Touch
Aug 29, 2017 | iPhone Apps
Kenwood KDC-BT652U car stereo is, what I believe, frozen.
first of all turn off it and get it down brok it and then enjoy the music
Feb 20, 2014 | Kenwood KDC-BT652U
How can put background on my kvt-514
1. Plug a USB drive with the picture(s) you want on the KVT-514 into the USB input. - If there is any music or videos on the usb drive, the USB function of the player will try to take over. If this happens, change the function to something else (DVD or FM radio, etc... anything EXCEPT USB) 2. Go into Setup (is bottom button on main screen on US versions) 3. Select "User Interface" 4. on the first page, there should be some background options. The first is the current background (and a way to change to any loaded picture). The second is what you need to pay attention to. There is an "Eject" symbol Button and a "Memory" button. Select "Memory" - It may take a little while, as it will read the USB device. Be patient. 5. After it reads the USB drive, it will display the contents as a external drive (it displays files, folders, etc.). Folders with files that the radio recognizes (pictures, music, videos, etc) will be highlighted in a bright white text while folders not containing them will be grey. Select the folder that the file is in and then the file. Alternately, if the file is in the root (not in a folder), just select the file. The transfer may take a while, be patient.
Hope this helps you.
Mar 30, 2010 | Kenwood KVT-514 Car DVD Player
Frozen player.
press the RESET button ....on the back
Mar 26, 2010 | Samsung YP-K3 MP3 Player
The screen is frozen and I cannot play music and i cannot find the reset button
If your Sansa Fuze MP3 player becomes frozen or unresponsive, you may need to reset the unit.
To do so, simply slide and hold the Power button on the side of the unit. Hold it for about 10 seconds and the player should reset.
If this does not work, I recommend plugging the device into a computer, or charger.
Jun 02, 2009 | SanDisk Sansa Fuze MP3 Player
Music mode screen is frozen after listening to FM radio
press the middle button and the power button for q0 seconds
Oct 11, 2008 | SanDisk Sansa e260 MP3 Player
Transfering music from my computer onto my phone.
Hi All
I had this issue and solved it...so thought id share....
if you go into the settings of your phone and choose connectivity option, then usb, you can choose how you want your phone to be picked up by the pc...your options are
Mass Storage device
LG Suite (default)
Music Sync
Always ask (will offer you the options above everytime you plug the USB in)
Choose Music sync (or better off the "Always ask" option as you may want to use other features) and then it wll pick up the phone in the suite
Hope this helps!!
Jun 17, 2008 | LG KU990 Viewty
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Downloading music onto mobile
I have done this 2 ways.
1. Use a MicroSD card and transfer the files directly over. I could not create a directory called "music" because the phone did not recognize that folder.
2. Hook up your phone to a USB cable and set the connection mode to music sync. Plug the phone into your computer and choose the option to Sync music files when the screen prompts you what to do.
Nov 22, 2007 | LG Shine KE970 Cellular Phone
FROZE UP
The same thing just happened to my iphone. I held down the button on top and the round button at the same time for about 5-10 secs and the phone reset itself. Hopes this helps
Oct 02, 2007 | Apple iPhone Smartphone
Sony Walkman NWZ-B105F MP3 Player Logo
126 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
