Question about 2wire (1000-000057-000) Modem
2Wire Wireless Modem 2700HG-G
Want to use with D-link adapter, will connect but won't allow internet access. Have 50% strength, was told to change channel on 2Wire to 11, how do you do this?
Access gateway.2wire.net
home network icon
wireless setting tab
channel dropdown box=11
save
P.S u should know ur PW to do this
Posted on Nov 09, 2008
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
Connected io router with excelent signal but won't connect to internet , using Beklen adapter , happened overnight.Did work well before.
It sounds as though you are using both a belkin wireless router and the 2wire 2700HG-B Router.
Setting up 2 routers to work together can be tricky and unless there is some specific reason to do so I recommend you just use the 2wire router.
Oct 29, 2009 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2700hg-b modem/wireless router, my problem is i get lag while playing xbox 360 online, i get red bar to none , while my friend have all green bar,in the tv screen,also my laptop lose signal...
yeah a better modem would be the easiest thing to do because it's clear that the one you've got is either not transmtting properly or is just the unit you'vee got has a fault in it
Oct 15, 2009 | 2wire 2700HG-B Router (2700HGB)
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Slow identifying 2wire686
Are you trying to use wireless? If so, do you have poor signal? I would suggest browsing to your modems interface. Type gateway.2wire.net into your web browser. Click on the Homenetworking icon. Select wireless settings. Type in your system password. Increase the power of your wireless setting located towards the bottom of the page. You can even try changing the wireless channel. Save and then retry to connect. Make sure you are entering the network key correctly.
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
WUSB Linksys adapter connnection
check your dns value ,firwall,proxey server, ipaddress and router configuration also.
Jun 23, 2008 | 2wire 2700HG-B Router (2700HGB)
if you have posted the correct model, you cannot connect a modem to this router as it has it's own built in modem, so in effect the routers modem will not configure properly, remove your modem and try again as there is no reason why the key code numbers should not work, unless you have caps lock on when you should'nt or visa versa
Nov 19, 2007 | 2wire 2700HG-B Router (2700HGB)
Slow speeds compared to speedtouch 330 usb modem
How do you connect to the 2wire 2700HG? Wireless or ethernet? In any case I suggest to access the mdc (management and diagnostic console) of your 2wire and check the DSL Diagnostics under the Troubleshooting Category. Check the attenuation rate of your 2wire there so you can see if external problems are affecting the 2wire. The 2wire is also a modem\router and eventough it rarely affects the speed of your connection, the 2wire Firewall might also affect the speed of your cx. Another thing to check are the electrical interference on your 2wire. EMI (Electro Magnetic Interference) do affect the 2wire router greatly. I mean it LITERALLY. A great Interference can cut your signal strength from full bars to 1 bar even tough your just 10 feet away from the router. You can also check the Broadband Status on the Network at a Glance Page to check if the speed are jumping in and out. And also try to contact your Internet Service Provider or the 2wire direct technical support (1-877-3478680) for further assistance. God Bless!
Sep 16, 2007 | 2wire 2700HG-B Router (2700HGB)
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-000057-000) Modem Logo
473 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
