No internet signal between router and desktop pc.
Linksys (wire-type) Router to Desktop PC (Microsoft XP). DSL to house using AT&T phone line > filter > DSL Cable > DSL Modem > out of modem using ethernet cable to Desktop PC. We added a second Desktop PC, so . with instructions from at&t, purchased Linksys (wire-type)Router . . .now we take ethernet cable from position on modem to WAN port on Router . . .then use ports 1-4 to connect ethernet cable to PC's. While running Linksys's supplied Installer CD . . .when checking connection between router and pc - - -error message indicates no internet signal/data between the two. Cabling hook-up is text book. Please help troubleshoot! Thanks. jg 0551jeg@gmail.com
  • 905 Answers
Have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Posted on Oct 14, 2008
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
Can Linksys WRT54G2 connect between HP desktop with XP and Compac laptop with microsoft 7. Router's program is insalled on desktop.
yes.. do the following:
Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
then restart both computers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 25, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Is there a way to hook into my dsl internet to get wifi
Does your DSL not have a wireless router? If not, you can certainly get one for cheap...walmart has Belkin/Netgear/ASUS wireless routers for about $40...the instructions are pretty straight-forward. It's a cheap and easy. let me know if you need assistance.
http://www.walmart.com/search/search-ng.do?search_constraint=0&ic=48_0&search_query=Router
Jul 19, 2010 | Dell Dimension 4700 PC Desktop
I received a new 2wire 2701HG-B modem router for AT&T DSL (replacing an older 2wire that burned out) and was able to hook up laptops right away no problem, but desktop doesnt recognize new modem how do...
are you on windows XP, Vista, MAC ???
you start out by seeing if you can ping the 2wire. The ip address you ping from a command prompt is the 2wire's gateway, 192.168.1.254
(you can get to the command prompt by clicking start, then click run, and type cmd and click ok on windows XP)
(on vista, you just click start and type cmd right above it where it says start search and hit enter on your keyboard)
(MAC's have a ping utility located by clicking on the harddrive, applications, network, network utility, and then the ping tab)
a little black window pops open, thats your command prompt
type ping 192.168.1.254 and hit enter on your keyboard
if you dont get replies, then your computer doesn't see the 2wire.
call tech support at 877-722-3755 24/7 for further support if required. We can make sure you nic is config properly, working properly, your not being blocked by a firewall, etc.
Sep 13, 2009 | 2wire 2700HG-B Router (2700HGB)
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in 191.168.1.254 and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
THESE ARE DSL INSTRUCTIONS
Feb 16, 2009 | Linksys Wireless-G WRT54GS Router...
Trying to get my linksys wireless router to go on dsl .
All you need to do is change the Linksys router's IP address. Because the westell and the linksys has the same range of IP address that creates a conflict on your network that's why you can't get online.
First login to the setup page of your linksys router.
  1. Under the Setup Tab (this is the first screen that you will see after typing in the linksys router's password.) make sure that the Internet connection type is set to Automatic Configuration- DHCP, Then on the same page look for router IP address or LAN IP address. By default its 192.168.1.1, you need to change it to 192.168.2.1. And hit save settings. You will get disconnected from the linksys page, that is normal. If you want to log back in to the router page you use the new address of your linksys (192.168.2.1).
  2. Now you restart your computer to refresh the connection and that should get you online.
May 07, 2008 | Linksys Wireless-G Broadband Router
I have a DSL router provided by frontier. I am trying to make my desktop wireless. I believe that my DSL router functions as a modem also. I purchased a Linksys wireless broadband router. I can't not...
Your router should just be that, a router. Your connection is probably like fibernet the modem is actually on the outside of the house. This may help or may not but I have a linksys wired router that works very well but you have to go to their website in order to set up the router. You may need to look through your papers and find the web address to connect to the right site.
Apr 17, 2008 | Computers & Internet
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Computers & Internet Logo
351 people viewed this question
David Payne
David Payne
