THE Philllips SBC HC 8442 Cordless headphones. The red lighton the base goes on and the later on goes off. Shold it be red all the time if headphone is switched on? Thank you rames shah
robotek
  • 1512 Answers
SOURCE: headphone socket
Hi twelvetwelve
Are you able to get access to the rear of the socket and use a small screwdriver to push out the parts of the plug that have come adrift inside the socket? You may have to actually remove the socket from its PCB to get access. If you cannot remove the offending parts, then you may have to replace the socket. There is not alot more that you can do unfortunatly.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
SOURCE: Problem Installing batteries in cordless headphones
Having removed the soft pad, there is a flat sheet of plastic attatched that goes round the speaker (sort of doughnut shaped, with a hole in the middle where the speaker sticks out). Carefully pull this perpendicular to the speaker, and it'll come off (the four rectangles you can see on the surface of the sheet are pegs that click into the main body to hold it in place). Under there will be one battery compartment. Repeat both sides, and you're done. This stumped me for ages!
Posted on Feb 02, 2009
  • 121 Answers
SOURCE: Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Posted on Feb 26, 2009
SOURCE: I have no instruction manual but would appreciate someone telling me whether I should charge them up with headphones switched on or off. I don't want to damage them! Many thank you's!!!
I decided to take a chance and charged them with earphones switched off. It worked fine. Thankyou for having a such a useful site. I'll certainly recommend you to my friends, even though I wasn't helped on this occasion! If I were to come up with a more difficult problem, then I'd willingly pay for assistance.
Posted on May 13, 2009
SOURCE: connecting wireless headphones
stop connecting
Posted on Jul 06, 2009
Were can i plug my cordless head phone's in?do i need the yellow&red cable's?
You need the audio cable with RED (RIGHT channel) and WHITE (Left channel) RCA plugs at one end, the other end will have to match the Headphone base unit input jack which can be RCA or miniphone jack.
The cordless headphone base unit can get the audio signal from the TV headphone output jack or from the RED and WHITE RCA audio line out on the back of the TV.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Televison & Video
Have Philips wireless headphones SBC HC 8445. Batteries appear to be charging and there is power. Works on left side but no sound on right side.
The speaker on the right side of the headphone is dead and shorted or might have lose wiring requiring repairing like resoldering or just tapping on the right on the right side it headphone might work.
Mar 21, 2011 | Televison & Video
My new philips sbc hc 8445 head phones are to tight on my ears please help
If it doenst have an adjusment on the band to losen it then take and flex the band several times but not to much you could snap it. That should help though.
Jan 04, 2011 | Philips (33-01-031) Headphones
How do I replace the batteries in the philips sbc hc135 headphones
i got a problem too with my SBC HC 135. I never use it before, i found it in my brother's cabinet. I tried to connect the adapter (which is have 5(if im not mistaken) red lights) to the socket. and all the lamps are lit. then i tried to turn on the headphone, but the lamp is not lit. i got a little confuse about how to use this thing. What should i do?
Nov 06, 2010 | Philips SBCHC130 Consumer Headphones
I have a purchased Philips sbc hc8445 cordless headphones. The sound in the headphones is no louder than what is on the TV. Am I doing something wrong.
I have lost the charging cable for the cordless headphones.
Is there any sample of the jacks as i'm in the midst of searching the cable.
Jul 30, 2010 | Philips (33-01-031) Headphones
Is it possible to connect my headphone SBC HC 8395 to my PC and to wich outlet do I have to connect?
i cant see from any website, but one i did translate - looks like a standard Jack plug, if so it should work OK - you can also get adapters
If a PC - should have a headphone socket at the front, or it may be on the back audio card outputs - sometimes coloured Lime Green - or on a laptop - you will have the socket on the front or sides - usually with a headphone symbol OR sometimes coloured a lime green
Apr 12, 2010 | Philips Audio Players & Recorders
How to hook my Philips cordless headphone SBC HCO75 up to mij tv set and instructions
http://www.p4c.philips.com/files/s/sbchc070_00/sbchc070_00_dfu_fin.pdf
is the link you must use to get all information you may need. copy and paste the above link to your browser. Good luck Don't worry about the model number.The principle in which they all work is the same.
Jan 23, 2010 | Audio Players & Recorders
The volume on my headphones are to low
if you are using an ipod then go to itunes highlight all music right click it, then click get info, volume adjustment +100%
Feb 02, 2009 | Audio Players & Recorders
PHILIPS HEADPHONES SBC hc 8440
Hi there!
OK I know it is little late to response but if someone will google it, might find the solution, they are still selling it though. I just got my set as a xmas present so here is the way it works..
First plug the batteries into the headset, there is gonna be small power in it, however you have to charge it. So connect the small charging cable into the base unit and the headset and make sure the switch on the head set is off. Green LED light will appear on the base unit. Let it charge for 16 hours. After is charged you can unplug the small charging cable.
OK now how it works.
The base unit needs to be always plugged-in to the electricity supply. Connect the audio connector from the base to the e.g. TV, PC, DVD player, mp3 player... After you plug-in the audio connector red LED light will automatically light on the base unit.
There is is two channels what you can use, that's in case if you have two of the same wireless sets. So if on the base is set to # 1 the headset needs to be also on # 1. Then if you have second headset choose channel # 2 on the base and also on the headset # 2, so they are not crossing each other.
Now press switch on button on the headset and red LED light will appear. There is nothing wrong with the red light. That's just the way it is..
OK that's it. Adjust the volume on the headset and you should be able to listen to the music.. :)
Hope it was helpful.
Michal Bohucky
Jun 01, 2008 | Audio Players & Recorders
Not working
Check if the power signal in the base turns on. If not two things can be appening. The base or it's transformer is damaged, or the output jack of you soundboard is dead. Check the sound form the soundboard with some regular headphones to find the source of the problem.
Make sure that the base and the wireless phones are on the same channel and you batteries are fully charged.
Dec 01, 2007 | Philips (33-01-031) Headphones
854 people viewed this question
 Grubhead
Grubhead
