Question about Panasonic FP-7735 Black and White Copier
Panasonic FP 7742 Copier
Error Message reads
Machine error E3
turn power off/on -40
Turning the power off/on does not do anything. Still get the same message.
  • innoniz Oct 15, 2008
    Machine error turn power off/on
  • Anonymous Feb 25, 2009
    SAME PROBLEM. :(
Check drum and drum sensor. if the Drum cleaning blade (DCB) has failed and is smearing toner around the drum then the drum sensor can't see the drum. clean it with a brush. the sensor sits in the drum/ cleaning station.
Posted on Nov 05, 2008
Panasonic FP 7718 error e3 40
E3-40 means there is a problem with the machine reading the black level density...this is not normally due to a faulty component but is normally due to to dirt inside the machine and possibly old/worn developer and /or drum in the machine. These are items that would have to be replaced by a service man.
Feb 03, 2011 | Panasonic Office Equipment & Supplies
E3 100 error FP 7815
the error would be E3-10. this occurs with a high voltage power leak on charge corona unit. either the corona wire is broken or the unit is dirty resulting in high voltage loss. clean or replace as neccesary
Jul 19, 2010 | Panasonic FP-7750 Black and White Copier
The machine does not make copies showing an error E3 which i can not see where i can find it
yep!
e3 means a machine error and it need a service technician to fix it.
furthermore may i ask what e3 code displays on the screen (you might see something like this e3 10 , e3 40 , e3 01 etc)
i can still help you if it is e3 10
Jan 04, 2010 | Panasonic FP-7735 Black and White Copier
ERROR CODE E3 -50 (PANASONIC FP 7742)
E3-50 is the malfunction of the transfer wire cleaner. The transfer wire assembly is under the drum. The transfer wire is on the right. The cleaner moves back and forth. If you feel comfortable taking it out, respond. There are fine metallic wires in each slot, so don't break them
Oct 04, 2009 | Panasonic FP-7735 Black and White Copier
I have a panasonic fp-7824 with an e3-40 error. What does it mean?
means copy density sensor output detection. try turning power on and off, then look at the copy quality
Dec 09, 2008 | Office Equipment & Supplies
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
Panasonic FP-7735 trouble shooting
That could be a few things. Your corona wires might need replacing. Something with the middle transport section, where one of the corona assemblies is at, is not making contact properly. Or it could be the high voltage power supply.
Nov 05, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 Error Code E3 40 Help!!!!
E3-40 is a toner density sensor error. It's probably toner getting built up on the sensor. It's located under the drum. It will look like 2 little LED looking things on a little circuit board about 3-4 inches long and half an inch wide. You can blow it out with canned air.
If that doesn't work, then the sensor needs to be replaced.
Oct 21, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 Black and White Copier Logo
240 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
