Got a very old Dahle 34x47" guillotine cutter. The spring on the bar that holds the paper in place while I cut it is no longer working. Is there a spring I need to replace?
    Genius:
  • 2,120 Answers
Posted on Oct 14, 2008
Removing cutter
Is this a guillotine style cutter or a rotary style cutter? What brand/model? Some rotary cutters are self sharpening and some cannot be sharpened.
Jul 12, 2014 | Tools & Hardware - Others
Polar 115EM,1987 guillotine
The machine may not handle compressed board well. If it works well with othe stock, the answer may be to stop trying to cut it. I know with my manual paper cutters some material does not cut well.
Nov 15, 2013 | Kitchen Appliances - Others
How many pages can I cut in a paper cutter?
Depending on the cutter you can cut up to 15 pages. To be safe you might not want to try cutting more than 10 pages. Cutting too many pages can ruin the hinges of the guillotine.
Sep 29, 2013 | Office Equipment & Supplies
Can I replace the blade on my paper guillotine?
On a paper cutter with blades that slide on a track you are able to replace the blades but not on a guillotine, it appears the only solution is to buy a new one.
Tsp100 not cutting receipt
the Auto-cutter on that model is only a 'partial' cut, (Guillotine-style.)
Since it is an Auto-cutter, if it is not cutting AT ALL, that is not something that a "user" can adjust-for.
See section 7-3 Releasing a Locked Cutter (pg 26) in your manual here:
http://get.acclivitysoftware.com/copdfs/TSP100PrinterManual.pdf
Nov 02, 2012 | Star Micronics TSP100 Thermal Printer
While typing there was a metalic "clunk. The paper would no longer remain around the bar.
There is a strong spring tha holds the lower rolls on the paper it may have broken but more likely the plastic point where it hooks broke off.
DickyO
Jun 24, 2012 | Brother SX-4000 Typewriter
Husquvarna 460 rancher 20" bar all new including
The normal reason for a saw to cut to the left, or right is because the cutters have been sharpened more on side than the other, they are now longer on one side, this then sends the cut off to that side. Measure the cutter lenghts, take the correct file and shorten the longer cutters
Mar 06, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
My clippers are no longer cutting. I took it apart today and cleaned out all the hair but I still can't get it to cut. I felt it and it's very sharp it's just not cutting any hair. I have been told it...
there is probably hair stuck between the cutters
remove the cutters from the clipper and you can push the top blade out from under the spring retainer making sure you keep the small plastic runner strip
clean the surfaces and using a flat bladed screw drive insert the blade under the spring and twist slightly to allow the top blade to slide back in
while it feels sharp , it is the sides of the cutter fingers that cut the hair ( like miniature guillotines) and those edges are easily worn off
May 04, 2017 | Remington Precision HC-8017 Hair Trimmer
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
93 people viewed this question
jasbo
jasbo
