Question about Sharp AL-1641CS Laser Digital Copier
All of my copies have toner on the right edge. How do I fix this?
All of the copies from my Sharp have toner on the right hand side, primarily on the edge of the paper. I have taken the toner cartridge and the drum cartridge out and cleaned it as much as I could and I still keep getting lots of toner on the edge of every page. How do I fix this?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
If it keeps coming back on the drum then replace drum.
Very unlikely that the toner is bad.
Posted on Oct 14, 2008
A copy has toner all over the right side on the paper.
Are you mean that toner isnt baked enough? If yes then you have problem with fixing roller bushings.
But if the toner is like printed, change blade and drum.
If the toner is like spiled on copy, vacume and clean the machine
Jul 01, 2010 | Sharp AL 1631 Copier
A thick black line of toner accumulates on the right edge of the paper
This is most likely caused by the drum unit. This unit is located just to the right of your toner cartridge. Just remove the toner cartridge first. Now remove the drum unit. Turn it over and look at the blue/green colored cylinder which is the drum. It should be clean. If you see a band of toner on one edge of the drum then this is where your toner on the copy is coming from. You will need the drum unit rebuilt or replaced. While it is out also check the front side of your toner cartridge. Just visually inspect the toner "brush" that runs all along the front side and make sure there are no piles of toner on it. Do not touch the brush or turn the roller.
Good Luck and Thank You for using Fixya.
Jun 30, 2010 | Sharp AL 1631 Copier
Colored lines are printing on the printed copies. It does not occur when we copy items, only when they are printed. The maintenance code "AA" is on the screen as well. I don't know what that code means....
When this happens, you need to clean the scanning area. When you lift the top cover, you will see a green clip on the right hand side (of the actual cover) and you clean the scanning section on the left hand side on both the bottom of the cover and on the base where you would put your original copies.
Then open where you put the toners in, and pull out on the green rods a few times each, and this will help clear the grid.
May 20, 2010 | Sharp MX-2300N Color Copier
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Added toner/copies still too light
adding toner to Canon copiers will not fix copy Quality problems. Do the copies look better if you manually adjust your exposure setting? If so you can clean the optics, which are the mirrors under the glass. Be very careful there are alot of sharp metal edges, that can cut you very easily.
You can use windex.
Apr 10, 2009 | Office Equipment & Supplies
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Nov 23, 2008 | Sharp AL-1642CS Copier
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-1631
Several things can cause this problem; The drum cartridge is not being cleaned properly or there is a problem with the toner cartridge . Take out the drum cartridge and inspect it for any signs of the defective image. If that doesnot solve the problem, then Call a tech.
Apr 20, 2007 | Sharp AL 1631 Copier
Sharp AL-1641CS Laser Digital Copier Logo
114 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
