Question about Sony VPL-VW100 (Ruby) Multimedia Projector
Sony PRojector VPL-VW100 runs for a minute, shuts off with blinking yellow light, manual says this is due to fan failure
Sony says to ship it 500 miles away and they will give me a repair quote. I would rather get the fan and replace myself. PN Airflex SFF21C PY51C. I can't figure out how to remove these fans.
  • Any Guy
    Any Guy May 11, 2010
    The problem with you replacing the fan is that you must get an original Sony fan, because the fans that Sony uses have rotation sensors that detect if the fan is spinning or not. If you just put a regular fan in there, the TV will not come on.
5 Suggested Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
SOURCE: high pitched sound from my sony VPL-VW100 projector
I have the same problem...did you ever get your high pitched sound fixed?
Posted on Nov 03, 2009
projdoc
  • 2236 Answers
SOURCE: Lamp timer reset not occurring with the remote control
with the projector in standby (lamp not on), press in order: reset, <-, ->, enter. then turn it on.
Posted on Nov 16, 2009
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Posted on Feb 13, 2010
omtronixom
  • 172 Answers
SOURCE: Sony VPL-CX5 projector won't reset after power
Please go to menu and check auto power on if it is on make it off
Posted on Aug 11, 2010
Shuts off fan blinks yellow
It sounds like your bulb has expired and needs to be replaced. Here's a link to a free manual which explains how to replace bulb.
http://pdf.crse.com/manuals/4074278111.pdf
Jun 10, 2014 | Sony VPL CS1 Multimedia Projector
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
Why is it in black and white and not color?
reset the settings to factory default and swap out the cable. if that doesn't work, you have a processor issue on the main board. it'll need to be replaced..
Feb 03, 2010 | Sony VPL-VW100 (Ruby) Multimedia Projector
High pitched sound from my sony VPL-VW100 projector
Nov 29, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
Sony Projector
Training manual sent from my Yahoo account: satguy84@yahoo.com
Should be on it's way to you now.
Nov 01, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
SONY VPL-CS3
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
Please help
what do you expect from SONY? get rid of it and buy another SONY shit.that's what they want you to do anyway.....
btw: maybe your lamp cover IS CLOSED??
Jan 07, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
Sony VPL CS5 Multimedia Projector Problem
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Oct 17, 2007 | Sony VPL CS5 Multimedia Projector
Sony VPL-VW100 (Ruby) Multimedia Projector Logo
80 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
