Question about Texas Instruments TI-83 Plus Calculator
Reset calculator I have taken both batteries out and pressed the on/off button for 30 seconds but the calculator will not cone on. What else can i try?
  • lblanken Mar 10, 2009
    Thanks for trying but it did not fix the problen. Also you only have to press 2nd one time and hold the up or down arrow.
Press 2nd then press the arrow up. Do it like ten times because it gets darker. For example...2nd arrow up, 2nd arrow up, 2nd arrow up, 2nd arrow up, and 2nd arrow up. If u press 2nd and the arrow down, it gets lighter. Try it. d[^_^]b
Posted on Mar 09, 2009
How do I reset the BD-107i Calculator?
Unscrew the door on the back of the calculator, take out the battery, wait 20 seconds, put the battery back in, put the door back on, and you should be good.
Good luck,
Paul
Jun 08, 2016 | Office Equipment & Supplies
Nothing shows up on the screen when I push any buttons. It will turn on, but after that nothing I push shows up on the screen. I have taken the batteries and the back up battery out.
Does the cursor show up at all? TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 29, 2013 | Texas Instruments TI-84 Plus Silver...
Where is the reset button?
To reset the calculator, remove all four AAA batteries. Press and hold the ON button for fifteen seconds. Replace the batteries.
Just out of curiosity, could you describe this weird behavior?
Sep 12, 2012 | Texas Instruments TI-84 Plus Silver...
Calculator turns on, but cannot turn off and no other buttons work.
If the TI-84 does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Aug 28, 2012 | Texas Instruments TI-84 Plus Calculator
My TI 84 calculator has random symbols that don't erase. none of the buttons really work and the button next to the (2nd) button makes the calculator turn off. however when i turn it back on the...
Reset the calculator by taking out all of the batteries, then hold down the power button for 30 seconds. Replace the batteries and see if it works again. If not, remove all of the batteries again, this time include the backup battery (you'll need a small phillips screwdriver). Wait 5 minutes and reinstall the batteries. Hope it works for you. g.
Sep 06, 2011 | Texas Instruments TI-84 Plus Calculator
I've tried to update my Calculator but now when i trie to turn the calculator on it gets stuck: The bar is at 100% and its says Loading operationg system.... I've waited for more than 1 hour and nothing!...
On the back of your NSpire there should be a small button that says 'reset'. Using a pencil or similar instrument, press this button and then try turning on your kindle.
If this fails to work, remove the batteries for around 30 seconds. Then replace them and turn on your nspire.
Cheers
Sine Wave
Feb 28, 2011 | Texas Instruments TI-Nspire Graphic...
I just changed the batteries in my calc and now it won't turn on. Is there a reset button?
There's no reset button. But TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't work, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries and turn the calculator on. (You may have to adjust the screen as described above.)
If that doesn't work, please append a comment to this post and we'll go on from there.
Aug 25, 2010 | Texas Instruments TI-83 Plus Calculator
Press
Have you tried to reset the calculator?
From page 671 of the TI-84 Guidebook:
To reset the calculator:
1) Remove all AAA batteries
2) Hold down the On button for 10 seconds
3) Reinsert AAA batteries
4) Turn the calculator back on.
Note: When you reset your graphing calculator, the contrast sometimes changes.
Nov 05, 2009 | Texas Instruments TI-84 Plus Silver...
Screen fully black
Black-Screen/Black-Pixel Fix for TI-Calculator
This will erase all memory and reset defaults.
1. Remove 1 AAA Battery
2. Press and Hold 'ON' for 30 seconds
3. Replace AAA Battery
4. Adjust Contrast to appropriate level
If this fails, try again with ALL Batteries removed including
the backup Lithium Battery.
If all else fails, try the following reset procedure:
1. Remove ALL Batteries (inc. Backup)
2. Let Calculator sit with no batteries for 2~4 hours.
3. Hold 'ON' for 30 seconds.
4. Replace all the batteries (May be good idea to use new batteries
just in case old ones were dead)
5. Turn on Calculator
6. Change Contrast to appropriate level
- Remember to use correct batteries or calculator may not work. The
correct batteries are Alkaline, Rechargable Batteries are TOO WEAK,
Heavy Duty batteries are TOO STRONG.
Oct 09, 2008 | Texas Instruments TI-89 Calculator
TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
Sep 12, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
195 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
