Question about Sanyo Televison & Video
I HAVE A PHP42H1AN PLASMA TV. I NEED TO GET THE POWER ASSEMBLY BOARD FOR THIS UNIT. ITS THE BOARD THAT IS LOCATED BEHIND THE ON/OFF PUSH BUTTON ON THE FRONT OF THE UNIT. IT CONTROLS THE ON/OFF OPERATION,ACCESS FOR THE ROMOTE CONTROL SIGNAL AND THE GREEN ON LIGHT AND THE RED STAND BY LIGHT. THE PART NUMBERS I HAVE ARE:6102953763 AND AND 6102970036. ARE EITHER OF THESE PARTS THE ONES I NEED? IF NOT COULD YOU PLEASE PROVIDE ME WITH THE CORRECT PART NUMBERS PRICE AND AVAILABIITY? ALSO I WOULD LIKE TO KNOW IF YOU HAVE AN EXPLODED VIEW OF THIS TV. YOU CAN E-MAIL ME AT steve.burgard@tropicsupply.com
  • 1694 Answers
SOURCE: Won't power up
C702 102K / 2KV capacitor shorted,located near transformer,
possibly partly covered with glue.Use Sony part # 1-161-754-00
102K / 3KV for replacement. Check E994 pico fuse ( 2 amp ).
Let me know by rating my suggestion....T.
Posted on Oct 22, 2007
  • 1694 Answers
SOURCE: rear projection problem. samsung sp48t5hp
The board sits up high above the larger boards....one screw &
four plugs sounds right. Bad part is STK392-040. If you decide
to repair----replace both IC's for reliability. I use Panasonic brand
to eliminate re-calls. Re-set alignment....done....T.
Posted on Oct 31, 2007
Slinteriors
  • 8617 Answers
SOURCE: Hitachi 51UWX20B Projection TV
Hitachi part number JT23051 is Obsolete the new part number for the Deflection Convergence PWB is JT23051R its available from Hitachi for around 350.00
Posted on Oct 08, 2008
SOURCE: Will not turn on
if main power supply is working check sub power supply.should be 1.5 volts on pe 42 pin8 and 9.
if missing replace ce36 and ce 39. i mounted mine caps on foil side.
Posted on Dec 18, 2008
SOURCE: Phillips 42FD9954 plasma will not turn ON
I have a Phillips 42FD9954/17S and every time I try to turn it on I also get the power red light blinking and sometimes it will try to turn on with a bunch of clicking noises and it will be green for a while then turn red. What I do and its very weird but works, put a blow dryer on hot and blow it under the tv on the side of the power button for about 10 minutes and it will turn on. I took it apart and there is a heat sink that if i put the blow dryer directly onto it on heat it turns on in less than a minute. Can someone tell me how I can fix this heat sink? I cant take it off. I want to put some thermal compound to see if that works. Give it a try I promise it will work. The Red Light has to be on put the heat on it and then press the power button, if you hear it clicking and green then back to red you are almost there. Keep putting heat on it and it will turn on.
Posted on Mar 31, 2009
My LG Plasma 50PK550 doesn't show a picture when I push the power button. It will also shut off when I push either the Input or channel buttons.
Main digital board fault. Check and replace the main digital board. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 27, 2017 | LG 50PK550 50 HDTV Plasma TV
Have a sanyo 50" plasma
This tv problems are related to powering up the tv and sustancening the tv power source to the tv itself.Replaced the tv sub power supply board where the a/c power cord plug into it.Try website like Ebay.com to buy a whole new refurbish sub power supply board for the replacement.
Sep 06, 2011 | Sanyo DP50747 50 in. Plasma TV
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
I have a Hitachi 42" plasma/ 42HDT51 and the power
Replace your buffer boards they are two unit located on the right of the plasma if you are looking the plasma from behind. Do you have any sound?
Thanks,
Nov 21, 2010 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
Samsung model HP-T5054 Plasma TV .. Push power button it lights up and Tv clicks like it is comeing on but then dont..
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Oct 16, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Push favorite button and get "self check"
If your panasonic has intermittent power issues the tv will require service, power supply needs an adjusment that should be done by a service tech, if not then you will need a power board. Julio milleniumtvsvc@gmail.com
Jul 26, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
My TV will not Power On
Hi, this will happen if your power supply board is failing to regulate the proper current and distribute it through out the set. if you unit will not power up when you push the power button, this will confirm power board failure.
simply replacing the power board assembly will fix this issue.
May 21, 2009 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
HP 42' Plasma Won't power on, does not power up..Won't turn on
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
Jan 08, 2009 | HP PL4260N 42 in. Plasma HDTV
Plasma TV will not turn on
The 7 blinks means that the SC scan drive board might need to be replace but only after checking the voltages from the power supply. If the voltages from the power supply are normal, then proceed to replace the SC scan board.
Click here to find the board you need.
Dec 20, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
