Question about Kyocera KM-1505 Copier
How to clean the printer inside
Kyocera FS680, printing lines over the print. Have changed the toner but this has not helped the problem. In fact it is worse. What if anything do I need to clean?
  • ssw3 Oct 15, 2008
    Thank you,
    I will try that and let you know. The cartridge is a brand new one. However the density of the print is not good. Plus it puts lines down the middle of the page. There seemed to be the remains of a sponge under where the cartridge sits and I am wondering if this is the cause of the problem.
  • 24 Answers
You can use an aspirator to clean the printer inside, and if you have a little experience you can clean the blade inside the cartridge with isopropylic alcohol, and the drum too. How many times was the cartridge refilled?
Posted on Oct 14, 2008
My Dell 1720dn mono laser printer has not printed properly for some time - in fact it's dreadful! The letters and dark images have white vertical lines going through them, and some of the printing do
Change your toner cartridge. A properly working toner cartridge will never leave that much toner lying around. The white lines are an indication that either the toner is low, or the mag roller is defective.
Dec 05, 2014 | Dell 1720dn Laser Printer
Inch wide black line on paper printed on a Kyocera FS3920DN
Have the machine warm up as normal. wait for the ready light to show. Then open and remove the Toner Cartridge . There is a cylinder about 1inch in diameter called the "drum". this drum should be clean of all toner from one end to the other. with your fault I would suggest that this black 1" line is clearly visible on the Drum surface and coincidently in about the same are you have black lines on prints. to fix- replace faulty drum unit
Sep 13, 2013 | Kyocera Fs3920dn Laser Printer Monochrome...
KYOCERA FS2000D ecosys laser printer. I replaced the toner as per instructions. First print had a vertical line down right margin of page. So googled if I should be cleaning anything because it does not...
its probably on the developer roller look at it as you spin the roller you should see a darker than normal area wipe the roller with a dry cloth until you no longer see it if you are turning it the right way no toner will come out the roller will have a thin even coating of toner on it or try cleaning the charge roller on top of the drum unit it should be 1 of the 2 these machines need to have the oem toner
Mar 16, 2017 | Kyocera FS-2000D Laser Printer
I have a problem with the colour prints...there are different kind of lines all over the can i clean the laser heads?is there any automatically way?
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Try cleaning the toners and see if it makes any difference. You would also have an idea about the toner drum/ parts quality etc and check if they need to be replaced. Furthermore, issues with Laser Unit like dust/ toner dust on the lenses and mirrors inside the printer usually result in faded or discolored prints. For instance, faded text/ picture at certain areas or any color missing when you print.
Hope it helps! Good Luck! Thanks for using Fixya!
Magenta stripe down left hand side of every page. About and inch wide. Have checked cartridge installed properly. Have ran the clean procedures. Can you suggest anything.
Hi Cindy,
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, black streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Try cleaning it or replacing the Magenta Cartridge. If required, get the PCR Roller changed by a professional.
Let me know if any further clarification is required.
Dont forget to appreciate the solution if I could have been of any help!
Feb 28, 2011 | Kyocera FS-C5015N Laser Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Requist for sugasion kyocera km-1500 toner
it is support cnon np 1215 toner
first time
you clean copier toner unite clean complite previous toner then put canon np 1215 toner print ok
May 28, 2009 | Kyocera KM-1505 Copier
Dark bands on bottom of all printed pages from rollers?
When you changed the toner did you clean the printer? There should have been instructions that detail cleaning the charging wire and charging grid.
If you already threw those out please let me know and I can assist you with the cleaning. If the cleaning does not help than it could be a drum issue and I would recommend calling your servicing dealership.
Jun 23, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Print Quality
clean the transfer roller and inside the printer .........
Mar 05, 2008 | Kyocera Mita KMR-1810P Laser Printer
Kyocera KM-1505 Copier Logo
218 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
