Powermax boiler 155, when boiler reaches operating temperature the presure relief vale blow's off at 3 bar, when it cools down the presure go's down too, right down to zero needing a water top up before a next day restart, the whole system has been bled and there's no air locks, can anyone advise me please...
  • paul3341 Apr 06, 2009
My hot water is fine but cant get my central heating to work i have a powermax 155 pls help its cold
Posted on Nov 24, 2008
  • 147 Answers
Sounds likes you have a hot water system. Some where you have an expanion tank that is full of water and it should be half full. It will a round tank above the boiler and may even have a site glass on the end off it. It will have a special valve on it to lower the water level in the tank. The tank is to absorb the expanding water as it gets hot, and releases it when it cools down therefore preventing your relief valve from popping off.
Posted on Oct 14, 2008
  • butch welch Oct 15, 2008
    You may have a bladder tank instead. It is about the size of a five gallon bucket. It will have a valve steam in the top of it.Check the air pressure in it and it should be maybe 5 or 7 lbs. No water should come out of it if you take the steam out. This tank can be anywhere in the system but they are usually above the boiler. Good luck
My combination boiler vaillant turbo max is not building up presure what can I do ?
Check the warning pipe to see if water is coming out. If it is then the pressure relief valve is passing and will require cleaning\replacing. If the water in the system is dirty then the capillary tube to the pressure gauge may be blocked this normally means changing the gauge. If neither of those are satisfactory then you may have a leak on the heating system or heat exchanger.
If the pressure is going up but dropping off when the boiler cools down this indicates the expansion vessel diaphragm needs recharging or replacing
May 04, 2014 | Computers & Internet
How do I set the thermostat on my powermax 155 boiler so that the heating comes into action on a lower temperature
You should have a remote heat setting via a wall or on the front of the boiler dependant upon how it is set up. If in doubt as a Central heating engineer to install a remote one you can have next to you wherever you are in the house.
Sep 30, 2013 | Heating & Cooling
Ravenheat 80/20 boiler. the boiler looses water pressure but only when working in central heating mode. Boiler holds pressure indefinitely if central heating is not used,hot water can be drawn without a...
Hi, your boilers pressure should be holding 1.5 bar with the relief set about 3. If the pressure is below this the flow switch will cause the boiler to stop as theirs not enough pressure to operate. Another thing, does your boiler have an auto fill system or do you need to plug a hose in to fill it? If its an auto fill system and you lose pressure you could have a leak.
Sep 15, 2013 | Water Heaters
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
I have a Powermax 155 boiler that keeps losing pressure. Most of the time, I can usually work around this by closing the tap in the boiler until the pressure rises, but it's not working this time. I...
I would first check the switch on the front to ensure it is set for CH & Water. Push bottom of the switch, check you have a pressure of 1 bar on the gauge to the left of the front panel. If not, top up until it gets to 1 bar. Ensure a demand is being called for (the timer is asking for heat) by pushing the CH button until the grey line is alongside 24 hr. then check if the central heating pump vibrating. If still not come back to me for more info
Dec 13, 2010 | Heating & Cooling
My 2 group astoria over steams from top of warms up then in about half hr steam shoots out at the preasure valve doicky do i need a new one of those thanks greg
The pressure releive valve is pre-factory set to open if the pressure in boiler reach between 1.6 to 1.8 bars.
So either you have the presure switch (presostat) not working normal which supose to switch off the electrical element at 1.2 to 1.3 bars.
So look at the presure gauge at which presure the presure releive valve open and releive the steam out from boiler if it shown more than 1.5 bar the you need to check the presure switch since it does not switch off the heating element.
If the presure releive valve open below 1.5 bar then you need to replace the releive valve.
Good Luck
Mar 23, 2010 | Astoria Argenta SAE-2 Espresso Machine
I need to know how to set the heating and water and for how long to have the water heating up for, for one person. So probably need a manual of some sort. Also my boiler is 11 years old and I have just...
Hi british gas will take nothing over 10 years on a contract so don't worry about that there plenty of gas fitters who will bo repiars on i,t hot water should be on for how much you are going to use 2hours in the morning longer in the evening its how much you will use too how long you have it on
Sep 29, 2009 | Canon PowerShot A75 Digital Camera
I have a ideal mini c24 cobi boiler and it isnt holding pressure the are no leaks inside the house it just seems to be releasing the water for the central heating from the blow off pipe outside so i keep...
So the boiler relief valve is leaking? What is the boiler pressure when the relief valve leaks? The relief valve will have a pressure rating on it. If the relief valve leaks when the pressure in the boiler is lower than the relief valve setting then its just a bad relief valve. If the relief valve is leaking when the boiler pressure gets above the relief valve pressure setting then the relief valve is doing its job and there is another problem. Several things can cause the boilers pressure to go higher than the relief valves setting. It could be a bad expansion tank or one that needs to be drained and re-charged. It could be a bad cold water fill valve that isn't shutting off and is over filling the system, rasing the pressure above the relief valve setting. If this boiler also does your domestic hot water, I have seen where the domestic hot waters heat exchanger has a hole in it and the domestic hot water is mixing with the boilers water and over pressuring the boiler.
Jan 13, 2018 | Heating & Cooling
I have a bosch 24cdi rsf combination boiler reaching 3 bar pressure and blowing off through release valve. any suggestions.
if this occurs when the unit is in use for only hot water, there will be an internal leak in the secobndary heat exchanger, you will have to replace it. check first that the charging link has been removed when testing to ensure it is not passing.
if it happens when the heating is switched on then check the presure in the expansion vessel ( dump all presure from system and use a car foot pump with a gauge there should be 1 bar presure) that is the big red thing behind the pump, if water comes out of the test valve on the front of it when you try to test it or it wont hold the presure you will have to replace it (a nasty job you have to strip half the boiler) if you can pump it up make sure you release the presure in the system as you pump it or you will get a false reading
Sep 07, 2008 | Heating & Cooling
Heating & Cooling Logo
511 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
