Need to repair my HKTS 14 Harman Kardon Subwoofer
    President:
  • 624 Answers
Since this is a power sub woofer, it may have an amplifier problem that would require professional service. Yoiu can start by checking the fuse. Make sure the sub woofer is not plugged into the wall when you check it. Some of these powered sub woofers have the fuse right on the panel where the cord goes into. It may have a round cap and you turn it and pull the fuse out. If the fuse is blackend or you can see that the filiment inside the fuse it broken, you can replace the fuse with the same rating of fuse. The rating is on the metal tab at one end of the fuse or may also be listed right next to the cap for the fuse holder. If the fuse is not accesable from the panel, you need to remove panel and look for it where the power cord comes into the panel. It will be right in line with the power cord. The panel for most sub woofers are normally held on by screws all the way around the panel. You should only need to take the outside screws (around the edge of panel) off of the panel. The inside screws hold on the circuit boards, connectorsm and transformer.
If you had given more information about the problem with your sub woofer I could have given you a better answer, but with the limited information given all I can suggest right now is to check the fuse. That is always a good starting point. If you give me more information I may be able to help you much more, I have repaired many powered sub woofers but not this model. Most are very similar and can be checked with minimal effort. You would need to have a multimeter to check almost everything else with the sub woofer. Let me know if you have a multimeter and are willing to check it further. Anything less than a "FixYa!" rating is really not a good rating, so please do not rate this solution until we have had a chance to communicate more about the problem. That way I will not be given a bad rating when I have not had a chance to actually help you yet since I can not tell you how to fix your problem without more information.
Dave
Posted on Oct 14, 2008
WHY is my harman kardon HKTS 15 subwoofwer is making a booming sound
Disconnect the cable and check the impedance/ohms with a meter.If rated at 4 ohms then it should read near that value.For 8 ohms also the reading should be near that value.You can buy a cheap Volt ohm meter for under ten dollars.After taking the ohm reading,it will be easier to diagnose................
Aug 19, 2014 | Harman Kardon HKTS 14 System
Harman kardon hkts7 subwoofer problems
luis::
you have to open 16 screws to open the ts 7 logic board.
Mar 24, 2013 | Harman Kardon HKTS 7 System
check the audio stage and replace the audio stage ics
u 201,202,301. with TL074 ic
Hkts 12
It is either blown or you are overloading it and it is close to blowing. Check your wiring and make sure your amp is matched properly with how you have it wired.
Feb 10, 2013 | Harman Kardon HKTS 12 System
Hello, my Harman Kardon HKTS 15 sub woofer don'st work, the light that suppouse to turn from orange to withe when i turn on my receiver stay orange.could be the cable from my receiver to the sub...
It could be because of your subwoofer AMP is gone.
Temp fix: Disconnect the subwoofer wire from receiver for 20-30mins and plug-it back. It did work for couple of months.
Aug 22, 2011 | Harman Kardon Audio Players & Recorders
I am getting no sound from sub. The turns on, but so sound. I have connected to two different receivers to verify it isn't the receiver sub output.
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
Jan 30, 2011 | Harman Kardon HKTS 14 System
My HKTS 7 Sub woofer makes no noise,the led burns from amber to blue as normal,and every so often i hear a low rumble noise. The Sub is powered and has 1 cable to the receiver, the fuse is also good.
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Dec 04, 2010 | Harman Kardon HKTS 7 System
Subwoofer is not responsive
big red
i think it migt have a broken wire replace it to be sure
Oct 16, 2009 | Harman Kardon HKTS 14 System
124 people viewed this question
 Grubhead
Grubhead
