Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Replace primary belt
Need diagram to replace belt
  • rtaylorzpc May 11, 2010
    While cutting the grass with my 42" 19.5 HP Craftsman Lawn Tractor, suddenly the belts began to smoke. I immediately switched off the engine after disengaging the PTO lever. After trying to restart, however, it seems like the PTO is still engaged and the engine won't turn over at all....like it already has a load on it. Any suggestions?
  • 14 Answers
here you go. (should be a diagram pictured below). If no picture, then the belt routes from the engine pulley on both sides (goes around the pulley) and goes strait back in between the two smaller pulleys, one an idler, the other spring loaded tensioner. The belt goes left with one leg, right with the other (from front or back) and engages both pulleys. Then goes to both blade pulleys and around them, then "meets" each other at the rear of the deck, running  strait from one blade pulley to the other.replace primary belt - image.tiff
Posted on Nov 22, 2008
Primary belt rubs on bracket n keeps shredding/// new replace ment deck...just purchesed
Look under the the left foot rest,there is a belt installation diagram. It will show how to install the belt correctly. It is real simple to replace belt,but the belt must be installed on the pulleys,correctly or it will fail,every time. Sincerely,Brad Locke
Jul 27, 2015 | Craftsman Garden
Need diagram for belt instalation for murray 46" cut
Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
Apr 21, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
Primary/secondary ignition coil failure
Cylinder 1 is the first one on the passenger side of the engine (nearest to the crank pulley,belts etc.) the next one over is #2 etc.
Jun 01, 2013 | 2009 Toyota Corolla
Belt diagram for a murray 46 model 46573X92A
This has a couple of diagrams with belts. Hopefully it has what you need. If not let me know and I'll keep looking for you.
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-46573X92A-LAWN-TRACTOR-(1998)-PARTS-LIST.pdf
Jul 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
Primary belt motion belt diagram for a murry 46 inch cut 2006 model
just did another murry today there is a sticker of the belt routing on the bottom of the foot rest
May 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
The belt broke ,need to change 2002 roadking
Replacing the final drive belt is a major job. You'll have to drain and pull the entire primary including the inner primary cover, the entire primary drive, and starter. You'll also have to remove the rear wheel and the swing arm to replace the belt. There are some special tools that you will need especially if you have to pull the front belt pulley to check it for wear or to replace any seals that may be leaking. If you plan on doing this job yourself, I'd highly recommend the purchase of a service manual. It's not a small job.
Good Luck
Steve
May 15, 2011 | 2002 Harley Davidson FLHRCI Road King...
Need a drive belt diagram for a murray lawn mower model 465306x8
Please find attached a "amateur" drawing of the belt routing for the 37x89MA primary deck drive belt. Hope this helps.wefixem.jpg
Mar 03, 2011 | Murray 46 Primary Lawn Mower Blade Belt...
2001 suburban. how to change a/c belt
2001 Suburbans generally have two belts. The primary drive belt and the A/C compressor belt. You must first remove the primary drive belt before removing the A/C belt. They are both kept in place with a tensioner. A standard 3/8 rachet will help give you the leverage to disengage the tensioner and remove the belt. Replace in reverse order.
Jul 30, 2009 | 2003 Chevrolet Suburban 1500
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
2,289 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
