Question about Husqvarna 160 CC Honda OHC Engine 21 in
MODEL 5521 RS
THE "ONE TOUCH" CUTTING HEIGHT ADJUSTING LEVER WON'T STAY ON THE SETTING THAT I'VE SELECTED. THERE ARE SEVEN (7) CUTTING HEIGHT SETTINGS AND IT JUMPS DOWN TO THE NEXT LOWER SETTING WHILE I'M CUTTING THE LAWN. I AM NOT BEING OVERLY ROUGH OR JARRING THE WHEELS....IT JUST SEEMS LIKE THE LITTLE ADJUSTING "NUBS" DON'T PROTRUDE OUT FAR ENOUGH FOR THE ADJUSTMENT LEVER TO STAY AT THE SETTING I'VE SELECTED. WHAT TO DO ? THE MOWER IS ONLY TWO WEEKS OLD... THANKS, PAPA DUDE
Hi have a 550 horsepower lawnmower and the height adjuster handle has broke where do i get my hands on a new one anybody out that can help please let me know thanks mossieirwin@hotmail.com
Posted on Oct 27, 2008
The cutting height adjustor pedal drops to low cut setting? Why?
the adjustment rod screws into a threaded receiver raise the tractor and screw the threaded screw back in then make the adjustment. Good luck
Feb 11, 2016 | Husqvarna Garden
Model KDL 46HX800. Why does it turn on, then off and red light blinks seven times?
7 blink by it means the internal temperature problem. Can be because the main board is faulty. You have to change the mother board of the tv . Also remember that when you change the mother baord you have to make necessary setting through service settings.
check the link bellow there lost of sony tv models and its service modes are listed . surf with the model number.
http://electro-medical.blogspot.com/
Nov 09, 2015 | Sony Televison & Video
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
How to tighten kitchenaid mixer motor head locking lever?
Adjust the head height first, flat paddle should just clear the bowl. Te head height adjustment can be seen in by the hinge looking from the front when the head is raised. Screw in (clockwise) to lower and out to raise. You cannot get the head lock right when head height is miles out
Jul 10, 2014 | KitchenAid KSM150PS Artisan Series Stand...
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Won't cut on low height setting
there are several rods that support the deck if one is missing it can allow the deck to move in the wrong dirrection
May 22, 2012 | Garden
How to adjust grass cutting height on
some old mowers you need to unbolt each wheel and move them to a different hole
Apr 21, 2012 | Garden
I just replaced my clutch cable, but now that I've put everything back together I have a problem. The bike will from neutral to first and back without the clutch lever pulled in. However it also...
Good news, you just need adjust the clutch cable..
Always order the part for your model and year when getting parts and make sure it matches in length with the old one. Note how much cable is sticking out of the housing.
Is it 3 1/2 inches or 4 inches or 2 inches. make sure the new one matches.
Put the new cable on with lots of slack.Slack at the adjuster, and slack at the handlebar adjuster
Now pull the lever in, it will be easy because of the slack.let it stay there.
It will stay against the grip.
As you tighten the cable adjustment down by the cover, you'll notice the clutch lever move out.
Once it reaches the top, stop adjusting and pull it in again.
Continue adjusting and pulling the lever until the lever springs back to the top.
You can feel resistence which is the clutches disengaging.
Make sure there is 1/8" free play when the lever springs back.
Now turn the clutch cable adjust on the handlebar outward, which will remove the rest of the slack.
Only leave 2mm slack on the lever.
Now start your bike up and it should work like new.
You want your clutch to disengage within the first 1/2" of pulling the lever in.
This ensures the clutches are definately disengaged by the time you get the lever pulled back to the grip when shifting.
If your clutches are slipping or dragging no matter how you adjust the cable then your clutches may need replaced.
But sounds to me like its just an adjustment.
Hope to be helpful
Big Al
Jul 25, 2011 | 1993 Yamaha FZR 600
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Husqvarna 160 CC Honda OHC Engine 21 in Logo
542 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
