Question about Velbon Sherpa DV7000 Tripod
Unfolding of tripod leg.
Sir,
I have purchased a velbon DV7000 tripod recently. Ican not unfold one of the legs of the tripod. could you please suggest me some tips to solve the prolem?
5 Suggested Answers
sblood
  • 23 Answers
SOURCE: One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
Posted on Jun 07, 2007
SOURCE: Velbon VMATE-607/F Tripod - Broken Leg Lock
duct tape
Posted on Feb 27, 2008
SOURCE: parts for a velbon tripod
I broke the release lever on my Velbon Ultra Lux tripod and looking for a replacement.
Posted on Sep 19, 2009
SOURCE: DV7000 tripod locking screws for legs and for
Hi, Folks!
I just cracked the Velbon's DV-700 tripod head mounting screw, that is on the top of the extending column. I need a replacement for this. Screw is on the top of the column.
Any suggestions?
Thank's in advance
Posted on Jul 02, 2011
I'm looking for the Velbon Videomate 601 instruction manual for my tripod.
Is a manual or instruction leaflet really necessary ? Tripods are actually amazingly simple to use. You spread the three legs (three legs - 'tri'-pod) and place them firmly on level ground. Then you attach the camera, camcorder, spotting scope or whatever to the top, and use the equipment as desired.
Sep 13, 2017 | Velbon Photography
Is there a "lock" position on on the 3 leg spread of this tripod?
-Providing that the image shown is the tripod you own..., the top leg lock levers on each leg is designed to lock the spreader angle of each leg.
-If this is not holding the leg at the correct angle...., either you are putting more weight on it than it was designed to hold..., or the 'cam' on the various locks has worn.
-A 'stop gap' fix for this problem is to insert a very thin wedge between the lever & the leg tube..., thus providing a greater amount of pressure on the tube, (this would need to be done every time the tripod is set up).
-Replacement parts are not available for this tripod & they were not designed to be user serviceable ...., sorry!!!
Peter
Aug 25, 2014 | Velbon Aef-3 Tripod
How to unfold legs on a black and decker workmate 400
I happen to have that exact table in my basement. It's hard to describe in writing... the 4 little legs just "swing" out from underneath. They pivot all the way out and wind up sticking out of each corner diagonally. Maybe a PHOTO would be helpful. (??) Take a look.... 8ebe2078-2b2d-4577-90ff-f4c34ba61f79.jpg
Apr 09, 2014 | Electronics - Others
Need to replace the slide which attaches the three leg braces on a Velbon Videomate 607.
If you're in the UK or Ireland, contact Velbon here. For the rest of the world, contact them here.
Apr 19, 2012 | Velbon VIDEOMATE 607 Tripod
DV7000 tripod locking screws for legs and for central, extending column are missing, where can I get replacements
Hi, Folks!
Any suggestions?
Thank's in advance
Sep 24, 2010 | Velbon Sherpa DV7000 Tripod
Velbon AE spare parts
Hi Keypr.
For repairs on the broken Velbon leg, you can try and contact:
ToCAD America Service Dept.
300 Webro Road
Parsippany, NJ 07054
1-800-886-2236
Ask for an estimate.
Hope this helps,
Andrew
Apr 05, 2010 | Photography
Velbon DV 7000 replacement parts
Hi I need a locking clip for one of the Velbon Tripod legs any suggestions?
cheers
Wayne
Apr 15, 2009 | Velbon Sherpa DV7000 Tripod
Parts for a velbon tripod
hi there, i think you can obtain the parts directly from Hakuba USA. www.hakubausa.com they're the USA distributers for Velbon and will actually repair it... if you can't by simply replacing a part. also a phone # 1-800-423-1623 and a seperate # 800-886-2236 to order quick release plates.
Jan 04, 2009 | Velbon VideoMate Deluxe Heavy-Duty...
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Velbon Sherpa DV7000 Tripod Logo
48 people viewed this question
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
