Question about Canon ImageRunner 2800 Copier
Reset Factory Defaults
How do I reset my Canon Imagerunner 2800 copier/fax/scanner/printer back to factory defaults? The machine is password protected and the person that set the password is no longer here so we have no way of resetting. Please HELP!!!
  • 1 more comment
  • kclark872 Oct 14, 2008
    Solution did NOT work!
  • RyanHN Nov 15, 2008
    I have the same problem with a ir400
    canb u help?
  • Anonymous Mar 31, 2014
    default password is not working and need to reset it back to factory defaults
I fixed the problem with no help from your service....as a matter of fact, I mailed the guy back that "helped" me online and heard nothing from him either.
Good thing Im resourceful.......$15 WASTED!
Posted on Oct 15, 2008
Canon IR1024if system manager password
try the default password id, and password both same
7654321
Feb 11, 2014 | Canon Imagerunner 1025IF Grayscale Copier
Ir password
Try a factory reset. The factory default user and password is 7654321.
Sep 25, 2013 | Canon imageRUNNER C2550 Color Copier
I have replaced my photoconductor in my Lexmark x464 and I still have a warning notification comming on. How do I reset it?
Try:
To restore factory defaults:
1. POR the machine into Configuration Mode.
2. Use the down navigation button to scroll to the RESTORE
FACTORY DEFAULTS item on the menu.
3. Press Select. The machine performs a POR.
4. The RESTORE FACTORY DEFAULTS sets the MFP non critical
parameters back to the factory settings.
Note: Some settings are not affected: panel language, energy
conserve, paper prompts, registration margins, and page count.
May 20, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Is there a way to reset to factory defaults?
you need to enter to service mode * 2&8 simultaniously, then * after that select copier then press function then clear then press dc con then press OK after that turn off & on the machine
Jan 05, 2010 | Canon imageRUNNER 5020i Copier
How to reboot the ricoh aficio 1515mf. i could not use as all were password protected. how to erase all the password and memory??
To clear the memory (reboot) the RICOH AFICIO you will have to send it to the factory where they will wipe the memory and restore the machine to its defaults.
Nov 10, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Resetting the key operator password
You must return the fax to factory defaults.
press
Function
7
monitor key slowly 4 times
* (asterisk key)
6
scroll down to SHIPMENT SET
set
set
wait for machine to reboot
Jul 27, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
How to reset factory setting for Canon ir3300 copier?
Could try MMI clear to reset user settings to factory default. In Service Mode go to Copier > Function > Clear > MMI Then press ok.
To get into Service Mode Additional Functions (has * on it) > 2, 8 > Additional Functions.
Jul 26, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Ricoh IS200e Web interface password
default login: scanner
default password: password
Jul 17, 2008 | Office Equipment & Supplies
Printer Password
If you reset the network card on the 8008 back to factory defaults it will reset the web password back to 'sysadm'
To reset factory defaults power the pritner on holding down CLEAR, keep CLEAR held down whilst you power the printer ON, keep the clear button held down untill you see RESETT on the display.
Resetting factory defaults will reset all network settings EXCEPT - IP, Sub net and Gateway address
May 13, 2008 | TallyGenicom 8008 Laser Printer
1,720 people viewed this question
old marine
old marine
