Question about Hotpoint Washing Machines
We have a hotpoint ultima wt 741 1400 spin washer. it sounds to be filling and empying at the same time and error code f-03 appears. washer will not turn off unless switched off at the plug. thanks colin.
Called out hotpoint.error code apparently means pressure switch faulty.
Posted on Oct 15, 2008
Getting F-02 error code
wt-960 1600spin washing machine show error code f-12 each time
you switch on
Jul 21, 2014 | Hotpoint Ultima WF860 Front Load Washer
F 03 showing on machine
Yes F-03 indicates a faulty thermistor (it's inside the heating element at the back). Before calling an engineer, just open the bottom rear panel and check that the connector has not come loose (OR IN MY CASE FALLEN OFF COMPLETELY). This can happen if there is a spin cycle that runs out of balance big time. (two thin wires on a square unit about 5mm in size fitted to the middle of the heating element).
Jul 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WMD940 F-03 showing on display
The error code F03 indicates a problem with the pump out of the washer or a failure of the pressure switch that controls the water fill. This is a problem that you should have a technician diagnose and repair.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Hotpoint Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
215 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
