Question about SanDisk Sansa MP3 Player
USB 2GB Sansa express i pod with micro sd
Hello sir/madam
when i connect my i pod to the usb port of my computer i recevie the sandisk mouse with computer icon indicating that it is connected. I also get the battery icon .But the ipod does not play or show any data on its properties.it also swiths off immedietly on swithing ON the player.
The same model another ipod on connecting it to yhe computer i get the answer as YOUR USB DEVICE IS NOT RECOGNISED. Please give me a remedy solution for both my ipod Whether it can be made serviceble or not' my e mail ID is jsrl_07@rediffmail.com
Thank You
  • SanDisk Master
  • 19,396 Answers
If you are using an USB extension or an USB external hub, get rid of it.
Try plugging the MP3 to a different USB port.
Try unplugging AC charger, and removing laptop batter for ten minutes, sometimes this can fix problems caused by accumulation of electrostatic charges on USB controller.
If that does not solve the problem, test a different USB device on the same laptop, and test the MP3 on a different computer. Either one may be faulty.
If the problem is the laptop you may fix it by removing and reinstalling USB root hub on hardware devices in Control Panel.
Posted on May 21, 2009
Format micro SD card
Hi, The quickest way would be to insert micro SD card into an SD adapter or plug it into some card reader, then stick it into the computer's usb port. Proceed to "My Computer" right click onto memory card and select "Format".
I hope this helps.
Aug 10, 2011 | SanDisk 2GB microSD Memory Card
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
http://kb.sandisk.com/app/answers/detail/a_id/200/related/1
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
My computer keeps saying it cant find my 4GB
Does the device work in *ANY* USB port on your computer?
Do other USB devices (mouse, keyboard, printer) work in the USB port that you are trying to use?
Does the device work in any *OTHER* computer (laptop/desktop) ?
Sep 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I put my sandisk into the front of my computer, and my computer hasn't yet recognized it. How do I access my pictures?
As stupid as this sounds, make sure the micro SD is in the correct slot and fits snugly. If you find that you don't actually have a micro-sd slot, you can purchase a piece that the micro-sd goes into creating a disk that's SD size.
If that's not the problem, go to Start > Computer > and look for the removable storage device. If it shows up, dbl click on it and see if your pictures come up.
If that doesn't work, you may consider buying an external card reader that connects using a USB port on your computer. That should work. If not, there is a strong possibility your micro-sd is corrupted.
Sep 05, 2009 | SanDisk 2GB microSD Memory Card
My PC will not recognize my 2GB Micro SD Card
Does the PC recognize the adapter when you place onto the USB port? If not, try another USB port. It should atleast say it has detected hardware, see if it's finding and installing the drivers correctly.
If it's not the adapter, could you reformat the microsd card? Perhaps, it is corrupted? Is this SDHC or SD (what capacity). Older Blackberries do not support SDHC (I believe this is 4gb or above), perhaps this has something to do with it.
I hope this helps,
Bill
Sep 04, 2009 | SanDisk 2GB microSD Memory Card
Sandisk 2GB cruzer micro USB not detecting
go to my computer property then hardware then device manager then uninstall usb drivers then right click any driver and clik on scan for hardware then it install automatic usb drivers.
then restart computer then connect sandisk to computer then cehck if still face problem try all usb port of computer.
Aslo check your usb port of computer are working fine.
Aug 09, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
Where to I put the chip in my computer?
You may have to get a card reader that takes stuff off and puts stuff on the sd card that connects to the computer using a usb port because most computers do not have an area where you can insert the micro sd card.
Nov 15, 2008 | SanDisk 2GB microSD Memory Card
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
178 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
