Question about HP 640 Inkjet Fax Machine
Won't send faxes to 817 area code, all others OK
New HP 640 fax has been working fine until we tried to fax something to a fax number with the area code of 817 (Texas). Faxes to this area code will not go through. Local faxes and faxes to numbers in our state (Tennessee) are fine. We get a "Sending Confirm" page printed after the aborted fax. It says "Mode: ECM" and "Result: Send Error."
Hope you can help.
If you need it, my email is wilhoitdiv@ugaais.com
Thanks.
    Genius:
  • 2,120 Answers
The recipient may have a DSL phone line, or receiving to a fax server that blocks your area code.
Posted on Oct 14, 2008
I can not receive fax but i can send fax the printer hp officejet5610 was at the client he receive the error that says fax fail brought the printer to my workshop the printer gives the same error please...
Hi, Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code.
  1. To modify the fax header, use the following steps:
    1. Press Setup on the product control panel.
    2. Press Basic Fax Setup , and then press Fax Header .
    3. Type personal or company information using the keypad, and then press OK .
    4. Type the phone number, including area code, for your HP fax product, and then press OK .
Regards,
Riztech
May 23, 2011 | HP Officejet 5610 All-In-One InkJet...
Hello, We can receive faxes but can no longer send faxes from our HP laserjet 3390. The display window shows a 9 infront of the number we are trying to fax, dials that number and then does not complete...
You have to go into the settings on the fax machine. There will be an option for a prefix number. Someone put a 9 in there. Having the 9 in there will make it dial a 9 then the number you are trying to faxt too. Remove the 9.
Mar 03, 2011 | HEWLETT-PACKARD Office Equipment &...
HP Officejet 6310 All-In-One InkJet Printer Changed home telephone system and now I can send faxes out but cannot receive?
Hi
Check the following link
CAN SEND but CANNOT Receive
  1. Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code. To modify the fax header, use the following steps:
    1. Press the Setup button () on the product control panel.
    2. Press 4 for Basic Fax Setup, and then press 1 for Fax Header.
    3. Type personal or company information using the keypad, and then press OK.
    4. Type the phone number, including area code, for your HP fax product, and then press OK.
  2. Dial 1-888-HPFaxme and send a fax to the HP Fax Test Service.
Jan 04, 2010 | HP Officejet 6310 All-In-One InkJet...
HP 640 fax won't send fax but phone works
Unfortunately wer purchased two new hp office jet 7610 which do not come with cabling and we could not get the fax to work. I spent 3 days on the telephone with hp and British Telecom each of which blamed it on each other. After doing some research on the internet I discovered that hp require a strange cable formant which is called a 'cross-over cable' is required. I bought them from cabling4less.co.uk and the product code is BT-203X. They can be found on their web site www.cabling4less.co.uk The link is: http://www.cabling4less.co.uk/category.php?cat_id=237 This should resolve this frustrating problem.
Jul 23, 2009 | HP 640 Inkjet Fax Machine
Hp 640 cant send or receive fax(NO ANSWER FROM REMOTE FAX
Since the fax machine is about 4 weeks old, why not give it back to HP? Warranty still covers it.
May 22, 2009 | Office Equipment & Supplies
Problem with my hp 640 fax
once you dial the number you fax will automatically start sending the the Fax signal which sounds like short beeps. This is done so the receivers phone (when answered) will recognized the beeps and switch to fax receive mode.  If you are getting the recording that you mentioned above, that means the number you dialed was not successful in making the connection.  Once you dial the number you should hear the phone ringing followed by some churping noises when the other end answers the call... then other churping and gargle like sounds initially as the fax proceeds.
sounds like your are having trouble with the number you are dialing.
Hope this helps..
~enov8
Feb 24, 2009 | HP 640 Inkjet Fax Machine
FAX TRANSMISSION
I have had this issue as well faxing to any area code in general outside of my own. The only thing I found to work was manual faxing. This comes from the manual.
Dial manually from the handset
1. Load the document into the ADF.
2. Call the recipient on the handset.
3. When the recipient is ready(when you hear the fax sound), press Start Fax on the product control panel.
Oct 03, 2008 | HP Laserjet M1319F Laser Multifunction...
HP 640 Fax...can't recieve faxes
You cannot use a four wire cable to connect the fax to the wall. You must use a two wire cable, like the one that came with the machine.  BTW, that means you can't you the EXT port to connect a two line phone or answering machine.
Sep 04, 2008 | HP 640 Inkjet Fax Machine
I have the HP640 Fax machine and I'm trying to program the distinctive ring mode but when I follow the instruction which state to press the menu button and scroll to advanced fax and press ok and then it...
I had been confused for the past ten months on this issue and just figured it out! Get a distinctive ring from you telephone service. If you have a answering machine, set it to answer on the 4th ring. On the fax, press menue til you get to the BASIC FAX, press OK, scroll the arrow button til you get to the DISTINCTIVE RING, press OK. Call your special fax number assigned from the telephone co, the machine should read DRPD OK, then on the face of the hp640 on the left i believe is a button called Rcv. Mode/Contrast, press that til you get to DRPD Mode, press OK. It should work great!! Hope this helps.
Jun 17, 2008 | HP 640 Inkjet Fax Machine
Can't get the Fax Machine to SEND a fax
Check to make sure that "mode" is correct. "Auto Receive", and/or, "fax" mode (not printer, etc.,)
Anne
Jan 25, 2008 | HP 640 Inkjet Fax Machine
Open Questions:
See all HP 640 Inkjet Fax Machine Questions
HP 640 Inkjet Fax Machine Logo
271 people viewed this question
Seeker5211
Seeker5211
