Phillips magnavox 55" projection
I have a 55" and the green and bluew are haloing aroung whites and like the show "House" everything is blue because the scrubs are all blue. The faces are sometimes blotchy because the colors are not blending. the lines are clear but then there is a fog or halo.
jeremymacho_152@hotmail.com
  • jeremymacho Oct 14, 2008
    Could this also cause a flashing in the colors making some of them flicker? Are you a tech or what is your resource?
  • techystumped May 06, 2009
    the picture seems good, but the colors are blended and the blue and red are all distorted, and the screen is foggy, giving the screen a yellow- greenish hue. I just got this tv today for free, and i see why..... I need help, but i need a free link, all the ones i've visited tell me i have to buy something
Could this make it squeal sometimes as well?
Posted on Oct 15, 2008
Could this also make the tubes squeel?
  • 8,617 Answers
The coolant needs to be changed in the CRTs ( picture tubes) this is a very common problem with all phillips and magnavox rear projections. Changing the coolant will restore the color and brightness and stop the halo effect. You can get the phillips CRT coolant kit at the following link and it includes all the coolant and the step by step instruction CD with pictures. Its actually a fairly easy job. Heres the link its listed under the repair Kit category.
http://servicemanuals.vstore.ca/
Posted on Oct 14, 2008
  • Sonny Berry
    Sonny Berry Oct 14, 2008
    yes it could also make the colors appear to flicker especially when the screen contrast is changing. I am a repair tech that has been doing projection screen repair since the 1970s.
Halo around blue, extremely bad when watching
The CRT coolant in the Blue CRT needs replacement. The green will soon follow. Very common problem with phillips. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant and the CD with instructions.
May 10, 2010 | Philips 60PP9363 60" Rear Projection...
We have Phillips 55 in rear projection TV and just set our color convergence back to factory settings but we still have an awful picture. Any suggestions? All objects have multiple halo bars on them....
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips 55PW9363 55" Rear Projection...
Phillips Magnavox constant blue screen
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 18, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red and fuzzy picture can you help on my 50 inch phillips magnavox projection TV
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around video.
You can see some example photos and find a solution here on Fixya.
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red "aura" in the middle of my 55" Phillips Magnavox
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
"Halo" Effect
Jan 19, 2009 | Philips Magnavox 55P9271 55" Rear...
60" Projection Tv - Approx 6 yrs old
Your CRT fluid needs to be replaced. After many years the crt cooling fluid gets a ton of alage built up in the tubes.  This will cause the screen to get a halo effect or get darker.
You only need to replace the fluid in the blue and green tubes.
Dec 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
Electro Med Services...
