Question about JVC GR-SXM260U Camcorder
No visual through LCD or viewfinder
Both LCD & viewfinder have black screen. Says pause and says lens cap on but it is not on. Will play back but cannot record.
  • Anonymous Nov 10, 2008
    blank screen but will play back the viedo
    Master:
  • 383 Answers
This is a Iris Problem .....THe Best in house solution is to Bang the camera Lightly with your palm .... other wise send it to a repairman .... coz you wont be able to open the camera to such an extent
Posted on Oct 16, 2008
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Black screen on my s6500 fd
I assume you removed the lens cap...;-)
If both the viewfinder and the screen is black, it is most likely an error on the CCD. If the viewfinder is OK, but the screen is dead, the problem is probably the LCD.
Hopefully you still have warranty on the camera?
Oct 02, 2009 | Fujitsu Cameras
Blank Screen
contact sony via their website, there is a problem with the CCD chip which causes your problem, sony did a free repair to my camcorder.
Jun 21, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
My Canon 300D SLR will turn on, and led display comes up saying battery is full and yet when you go to take a photo you cant see anything but black through the lens.
Obvious Questions, but you didn't supply the information.....:
1. Is the lens cap off?
2. Are you looking through the viewfinder? You will *NOT* be able to use the LCD screen as a viewfinder.
Otherwise, there is always a light path through the lens to the viewfinder, so....
1. Have you tried a different lens?
2. Have you checked the mirror is down?
May 26, 2008 | Canon Cameras
In Camera (Record) mode, does not show video at all, black screen
THIS IS YOUR CCD.. SAMSUNG IS VERY AWARE OF THIS BUT STILL CHARGES A ARM AND A LEG
Feb 06, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
No display in viewfinder and LCD
sorry to say but the problem of your camera is the ccd image sensor....go to a service center for replacing it...
May 07, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
JVC GR-SXM260U Camcorder Logo
172 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
