Saws Logo
Anonymous Posted on Jan 17, 2012
How do i remove old thinset?
I removed a large border of tiles and now i have to remove the thinset. I started using the Dremel thinset remover wand, but it's too slow and time consuming of a process. Because the area is small, renting a large piece of equipment won't work without damaging good area. The area is about 12' long x 9" wide. I've considered cutting out the hardibacker down to the sub floor. Does anyone else have suggestions?
Repair Ahjoshe
Level 3:
  • Master 885 Answers
  • Posted on Feb 01, 2012
Repair Ahjoshe
Master
Level 3:
Answers
885
Questions
0
Helped
642781
Points
2112
The best way to go in that size area is to rent a Hilti or comparable demo hammer and use a 3-inch wide bit. Make sure they give you a new, sharp bit. Adjust the angle you hold the chisel to the floor to where you get the most thinset off on each pass but don't damage the base floor. This will depend on how well the thinset has adheared to the floor.
I have a Saltillo tile balcony and the tiles are popping. There are no expansion joints, could that be the cause?
who ever installed it probably didn't use a tile underlay like wonderboard or hardibacker. Also for areas like that you have to get the good thinset mortar like FLEXbond and the other thing too is Saltillo is not very user friendly when it comes to installing if you're not fast because its so porous i literally sucks the moisture from the mortar and there for doesnt bond to ur surface. If the thinset is thick and dry it aint gonna work. ALSO WITH SALTILLO YOU MUST HAVE 100% COVERAGE WITH THE THINSET.. Hollow tiles or no thinset under corners and what not just going to pop up. I butter the floor AND the back side of the tile when doing that type of tile. It's not very flat so there for you must have alot of thinset mortar under each and every tile. good luck. hope this helped. I been doing custom tile for 25 years so i got ya on this. Who ever was the installer lacked some knowledge on Saltillo. Tear it up and get something nicer.
Feb 27, 2015 • Saws
tip
Tips on how to Get ready the Subfloor intended for Ceramic Tile Installs
Ceramic along with porcelain tile are generally among the most rigid supplies intended for floors. They require the subfloor that's which will take into account that, without any fluctuation and also motion. If ceramic and also porcelain tiles are generally set up on the wrinkled surface area, a person manage the risk connected with allowing the tiles to be able to break and also loosen. Locations recommendations on tips on how to get ready the subfloor for a tile assembly.
one. The installation of ceramic tile along with porcelain tile with a real piece
Repair many splits along with wrinkled pads from the real subfloor before the assembly - specifically crucial in the event the tile will be becoming specifically bonded to the real.
If connected with subfloors along with great splits, look at the chance of removing a large portion of real piece along with replacing that using a brand-new one as an alternative to patching all the splits.
Intended for negative splits from the real piece, smooth that along with real filler, and also related substance.
In the event the real subfloor will be brand-new, that have to be still left to be able to treatment 29 days and nights previous to tiling.
Personal hygiene will be paramount. Aside from virtually any surface area supplies, you'll want to take away virtually any grease intrinsic and extrinsic stains, and also alternative contents that have tarnished the piece because most effective it is possible to.
Bare cement backer snowboard can offer powerful, flat working surface to put in tiles on for those who have the real wood subfloor.
only two. The installation of ceramic tile along with porcelain tile with a plywood subfloor
The plywood subfloor have to be structurally seem along with capable to help support the assembly. Tile floors are generally hefty along with tile is a very difficult substance. It is going to bust and also dislodge in the event the surface area bends less than the fill.
Don't forget which you are required an extremely flat working surface to be effective on. If desired, stone dust the plywood into level the subfloor.
Plywood have to be set up over an acceptable subfloor along with have to be a minimum of one 1/8? heavy if put together with the subfloor. Interior-grade plywood along with particleboard are not deemed strong sufficient for a tile assembly.
three. The installation of ceramic tile along with porcelain tile over plastic floors
Non-cushioned plastic along with linoleum which is structurally seem along with unencumbered with high motion can certainly take action just as one suitable subfloor.
Padded plastic seriously isn't the perfect subfloor. You need to take away the plastic ground along with virtually any remnant adhesive utilised to the plastic assembly.
In some instances, it is possible to eliminate the plastic once more, however , not the adhesive. Use the skinny placed which is endorsed from the backer snowboard maker.
If it seems hard, you might want to lay out the backer snowboard along with thinset.
several. The installation of ceramic tile along with porcelain tile over a pre-existing tile ground
It is possible to sometimes keep the tile ground set up along with employ thinset specifically over that, and also take away the tile using a hammer, dependant upon the best way high the ground must sit down relative to be able to doors and also other internal factors.
In the event the current tile ground is focused with a mortar mattress, it really is very difficult to eliminate the tiles with no removing beautiful mortar mattress.
If you're the installation of specifically on the older tile floors, uncertain " up " the existing tile along with stone dust document. Clean using a degreaser along with analyze a little community suddenly intended for bonding.
In addition, test the height from the ground while using height of doors along with showcases. Any good thinset enable you to set up the brand-new ground.
Incorrect to order subfloors
Subfloors in order to avoid intended for tile installs are generally those that are inclined to bend, increase, contract, and also warp. Virtually any high motion may loosen the tile along with soda the grout. Incorrect to order subfloors have to be succeeded and also taken care of using a suitable underlayment. Here's a list of no-go subfloors:
Padded plastic
Border set up plastic
One layered plywood
Flake snowboard
Particleboard
Computer chip snowboard
Hard wood (strip) floors
Luan plywood
OSB planks
Masonite
Linen steel
Which kind of subfloor considering the installation of the ceramic tile on?
Continue to searching for the ideal tile to your renovation venture? Please click here to be able to consider the amazing group ceramic along with porcelain tile.
Wholesale Ceramic Tile from China Manufacturer Best price
on Jul 31, 2015 • Building Materials
How can you tile on blue board ?
In barhroom always use thinset. Modified.
Sep 14, 2014 • Saws
I installed bellavita glass tile 8x16 im having issues with mortar stickig to it and holding it on wall.. why?
Your not troweling enough glass thinset onto the wall. The thinset should be creamy and troweled evenly most people hold the trowel to flat or use to small of a trowel you also could lightly coat the back do the tile to give it a good mechanical bond
Can I buff out water stains on ceramic tile in a shower? Stains are very old. What accessory would I use?
high speed buffing will break down the glaze. there are several liquid stain removers available that may work better, and do less damage to your tile. hope this helps.
My apprentice used grout, intead of thinset to bond 250 sq ft of quarry tile to concrete. Is there a away to fix it? without pulling all the tile?
Grout is a non-adhesive concrete material that is made with sand and cement, with colorants added.
Grout will not adhere tile to any surface
The good news (if that's possible) is that the tile should be fairly easy to remove, and the grout will be fairly easy to scrape off the floor. Break one tile out of the way, and see if the others can be pried up easily.
Looks like you have to start over, sorry for that.
I was a contractor for 30 years >>> we laid tile for about 2 years and then shifted to other trades >>> I know from experience that the big disasters become great stories a few years later >> every contractor has those stories.
Let us know how it comes out.
1helpful
Tile over a cracked cement floor
You can get a crack membrane to put over the cracks. First use a primer on the floor, this is a primer just for this application, then put membrane on top of primer. these products can be found at home depot or lowes or any tile store.Also do not use cheep thinset. the better thinset is more flexible and will absorb any movement. The cement board would not work as they will move or flex and cause the grout to crack and tile to loosen
tom
Tasks usage
Cutting holes in wallboard, Removing grout, Deburring metal, Cutting fiberglass, Sanding in tight spots, Cutting the heads off stripped screws, Shaping metal, Cutting ceramic tile, Stripping old paint and varnish from woodwork, Removing window pane glazing, Grinding, Shaping and cutting in arts and crafts projects, Polishing metal, Engraving, Etching, Cutting marble, Cutting nails, Cutting plumbing pipe, Sharpening tools, Cutting wood.
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
