Question about Sony Ericsson Z525a Cellular Phone
Auto answer pushed wrong button phone on auto answers not accepting calls what do I do to get back to normal so the phone will accept outside calls?
    Master:
  • 383 Answers
Please reset your phone to factory settings .... it should work fine
Posted on Oct 14, 2008
How do I accept an incoming call?
You should have a look at your phones manual to get the BASICS.. You don't have a manual? Too bad!
The funny part of your question is that you are not specifying your cell phone.
Normally you accept a call by pressing tha "phone button" . Some Intelligent cell phones must be UNLOCKED before answering a call, by "sliding" the unlock button. Or maybe your's happens to be blocked / locked?
OK, between you and me, I believe you should ask site where they sold you the phone to show you basics.
An get that manual, please!
Oct 06, 2015 | Cell Phones
How do I answer a call from my headset?
Is the headset paired with the phone you are using? If not, you can pair the headset by pushing and holding for a few seconds a small button on the back of the 5330 phone until it starts flashing. The button should be near the top of the cordless module. When the phone starts flashing, push and hold the answer button on the headset until it starts to flash as well. There should be a prompt on the phone itself to select which device you want to pair. Let me know if this helps :)
Jun 10, 2014 | Mitel 5330 IP Phone
How do I tell if Auto Answer is On ot Off?
call it from your cell phone and see if it answers.
Mar 18, 2011 | HP Officejet 5610 All-In-One InkJet...
We have a Panasonix KX-T7731 phone system with 7 different extensions. How do I program each individual phone so that the date and time appear on the phone display?
With the handset on the cradle:
Press Program button
Enter *#
Enter the system password - system default is 1234
Enter 000
Press the Auto Dial/Store button
Enter date using the Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Dial/Store button to accept setting
Press Redial button to move to time
Enter time using Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Ans/Mute to exit Date & Time
Press Program Button to complete
Dec 30, 2010 | Panasonic KX-T7731 Corded Phone
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
My blackberry is answering when I open it
To use Answer button on the BlackBerry smartphone, complete the following steps:
1) On the Handheld press Call button.
2) Press the Menu key.
3) Select Options.
4) Select General option.
5) Select Auto answer calls to, (Never).
6) Select Auto end calls to, Into holster.
7) Click on save.
I hope I was able to help you.
Thank you for using Fixya.
Nov 11, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My kx t7730x doesnt have a ring but its receiving calls outside.
I'm guessing this is connected to a TA series system.
There is a ringer switch on the left side of the phone. Does it ring on intercom calls with the Auto Answer button not lit?
The 2 things that control the ringer for outside calls is the ringer switch and programming. Intercom calls ringing is controlled by the switch, Auto Answer button, and programming. If the switch is set to medium or high and the phone doesn't ring, try it at another extension. If it still doesn't ring, it's broken, if it rings, then you have programming issues.
Carl
Sep 11, 2009 | Panasonic KX-T7730 Corded Phone
I cant get the phone to accept the date or time or get the answer
You need to find anything related to auto date & Time , or auto update in time settings,
If you get that settings, then disable the auto update of date and time.
Jul 09, 2009 | Lands Phones
Ringing period
You may have the "auto answer" option turned on. To check, pull up the phone screen as if placing a call, push the blackberry menu button, select "options", then "general options". Make sure "Auto answer" option has "Never" selected.
May 03, 2008 | AT&T Blackberry Curve 8300 Smartphone
HP 5600 all in one
For this, you need to configure your HP All in One in "answer fax calls automatically" mode.
Follow the instructions as below :
Press Setup on the panel
Press 4 then press 2 ( This selects basic fax setup and then selects auto answer )
Press > to select ON
You may like to change number of rings before auto answering the fax. You can do this by :
Press Setup
Press 4 then press 3 ( This selects Basic Fax Setup and then selects rings to answer )
Enter appropriate nuber of rings by keypad or by < OR >
Best of Luck,
rajesh_im
Feb 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Sony Ericsson Z525a Cellular Phone Logo
57 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
