Question about Mitsubishi WT-46807 46" Rear Projection Television
Wt46807 internmintent problem
Hi ihave the same problem on my 46807 rear pro. i looked for the stk ic chip cannot find it..i removed the cover on circuitboard that is vertical where all the cables plug into still cant find it..looked with a mirror ..behind it,nothing.. could it be in one of those caged sections with the holes in the cages. there are like 3 or four . dont wana get shocked,,i did once before bigtime..!!lol ouch.. all help appreciated thanks Don12159@aol.com
or pictures would be great if have ?
  • Don Nov 04, 2008
    Thnak you i looked for the stks and i could not even locate the chip
    must be buried in there somewhere anyhow i bought a new panasonic but if i can fix it myself i might be able to sell it for more money ..play it by ear thanks email is its a 46807 mitsubishi 46 inch rear projection
  • dl2539 Nov 16, 2008
    i have same problem but cant locate IC
    Sergeant:
    Champion:
  • 227 Answers
HEY GIME THE MAKE AND THE MODEL NUMBER AND I'LL SEND YOU A PICTURE OF WHAT YOU ARE LOOKING FOR..... OK
Posted on Oct 20, 2008
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
65" rear pro. Convergence IC Repair
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Won't stay on for more than a few seconds
Replace Both of your STK ICs big black ICs will have # on them for example STK392-570 Call Mats for Parts 1-800-628-1118
Sep 24, 2009 | Mitsubishi WT-46807 46" Rear Projection...
I need a convergance chip but don't know where to get it
I learned today on my Mitsubishi VS-60621 (chassis VZ4) there are 3 convergence ICs (3, not just one as previously suggested), all 3 are STK391-020 located underneath the large heat sink on the upper right (as viewed from back of set), above the large PCB with the 6"x10" cover in the middle. The 3 chips are hanging upside down from their heat sink, have aluminum covers over them (so well hidden, it took me hours to find them, not knowing where to look), and the whole heat sink & chip assembly comes out by removing 2 screws, the front one must be accessed by removing the large lower front plastic cover and fiber-board piece behind it. Not necessary to remove the smaller plastic cover and control box above the big one. The big plastic cover has 2 large tabs on the bottom straddling the center post that will still hold it on once the screws are removed, gently pull down on them to release it. Not necessary to remove the glass doors, but probably safer to do so. Good luck!
Aug 27, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Removing STK-392-110 chip
Mine came off easy because they hardly used any thermal paste at the factory (doh!), but dont be afraid to pry them off. You have to get the "glue" off anyway, just dont bend the PC board or crack an edge when you do it. Try clamping the heat sink gently in a vice and use a tiny flat screwdriver and twist under the IC. Once unglued, you can bend the ICs away from the heatsink pretty far as you de-solder the pins. I would recommend you replace with the higher power chips (150s) also. They are identical in function but rated for higher power which might get you a few more years of life.
Feb 07, 2009 | JVC AV-56WP74 56" Rear Projection...
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
Wt-46807
IN YOUR CASE YOU HAVE COLD SOLDER, JUST PULL THE POWER SUPPLY AND YOU'LL SEE THE CONVERGENCE IC'S THEY ARE EASE TO INDENTIFY. THE NUMER STARTS WITH STK.....
CAYPIANAN@YAHOO.COM
Jul 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Toshiba 42H83 projection TV red convergence issue
the Convergence Ics are STK392-110 ICs you can get replacement Ics at the following link and they provide free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 03, 2008 | Toshiba 42H83 42" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
