Question about KitchenAid KEYS850LQ Electric Dryer
KITCH AID DRYER
I TURN MY SWITCH ON FOR 30 MITUTES TO DRY CLOTHES BUT I CHECK DRYER IN 1 HOUR LATER AND IT'S STILL ON 30 MINUTES AND NOT TURNING THE DRYER OFF UNLESS I TURN IT OFF MANUAL. WHAT IS THE PROBLE?
  • butch welch May 11, 2010
    can you do a timed drying, like a manual 45 minute drying cycle
    Are your clothes dry after 30 minutes. Is the dryer heating up.
    Scholar:
  • 145 Answers
Your timer motor is bad. There is 2 circuits that start and stop your timer motor and the most important on is when the clothes are dry (thermostat opens) your motor should start and time down.
Posted on Oct 18, 2008
YES MY DRYING IS HEATING UP. THE TIMER WILL NOT SHUT OFF AND STOP THE MACHINE FOR DRYING IF USE ANY TIME.
Posted on Oct 16, 2008
I have a Samsung DV431AGP. Dryer never stops clothes are done and just keeps running. Even in the timed mode. Starts up, drys clothes, and 1 hour later still has same amount of minutes left.
the cause of this is a bad timer switch it is the switch directly under the knob you turn to set the time on the dryer.You can purchase a new one on amazon or buy one from tribbles in timonium.
Sep 16, 2013 | Samsung Dryers
My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Jan 10, 2012 | LG Dryers
When I use the "More
maybe to blower fan of your dryer has already accumulated too much cotton debris. Usually you can access the blower fan by opening the side panel of your dryer to check it out. but before opening be sure that the unit is unplugged from the supply.
Dec 31, 2010 | Dryers
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer thinks clothes are dry but they are not
1 start with claening the sensor strips located just inside the unit itself under the lint filter. pop yourheadinside dryer drum andyoull see 2 metal strips. witha scotchbrite pad, give it ascouruing, to remove any build up form fabric softener / dryer sheets
2 check for good, not kinked or clogged venting
3 replace the thermsitor about 30 bucks.
Mar 22, 2008 | Whirlpool GEW9250 Electric Dryer
Gas clothes dryer not drying clothes
could be an ignightor problem reply and we can talk
Jan 03, 2008 | Dryers
KitchenAid KEYS850LQ  Electric Dryer Logo
196 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
