Question about HP LaserJet 1020 Printer
99% of printed page has light grey water mark-as if water-washed
The print on the page is lighter than normal as well. The grey water-wash effect is noticeable because there is a veritcal white strip 1/8" wide at the far left side of the page that runs the length of the page. Can you tell me what is causing this and if it can be fixed?
Thanks,
Amanda
    Novelist:
    Scholar:
  • 111 Answers
Are you saying it is this problem?
Gray Background Print Quality Defect
Here's another error that might fit the bill:
Vertical Lines Print Quality Defect
If these documents don't quite describe the issue, please post back with more details. Thanks.
Posted on Oct 15, 2008
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
When printing a page the main headings of the page comes out in focus and clear. However the information following the headings seemed to be double printed over each other, but slightly misaligned causing...
Align completed?.. Take cotton wet cloth( dip cloth in to normal cold water sqeeze it) clean encoder strip left to right once gently..check any markings on it?..do align once again I hope your problem will shortout..
Sep 14, 2011 | HP F4480 All-In-One Printer
The printer prints every page grey and the print is lighter than normal. the toner light is not on. should I replace the toner cartridge?
Your problem sounds more like a bad drum unit than a toner issue. You should try cleaning the corona wire first which you do by removing the drum/toner unit and looking for the little sliding blue tab. Move this back and forth a couple of times and then reinsert the cartridge and try printing again.
Sep 06, 2011 | Brother HL-2040 Laser Printer
HP 2600 is printing with a grey background. I have done several recalibrations and cleaned it but it does not fix the problem.
same as me, I got reduce this effect printing in normal paper as if i where printing transparency paper. The background is lighter now, but still appears.
The other thing I test, printing a blank page it was that with a glosy photo paper with the gloss side to the back i dont get any background. So i suspect it has to do with the tansfer belt ETB rollers.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
My Ricoh 3500 color printer no longer is printing in color--just greys. It does not seem to be a problem with the color cartridges. Also, it streaks from left to right across a page from light to lighter...
The streaking could be anything internal to the printer, such as the transfer belt or a drum unit. As for the lack of color, that sounds like it is a setting in the print driver that got changed from printing in color to printing in monochrome or grayscale. Look through your print driver settings to see if you can locate this setting and change it back to color. Also, once you print in color again you may notice that the streaking is a specific color, which will help to troubleshoot that issue.
Jul 02, 2010 | Ricoh Aficio CL3500N Laser Printer
6-part NCr paper form being used. Pages 1 and 2
This is a problem with your paper. Using multi-part forms on an impact printer will get lighter print on each layer working from the top form to the bottom. The "carbon" paper has to impact the paper hard enough to make the marks. If your top and bottom copies look good but some in the middle are light it is a problem with the "carbon" paper and not the printer.
Now IF the top page is light and each copy under that is getting lighter then you need to close your platen gap (the lever on the right side of the machine mark A B C) go one click at a time (darkening) until the print quality looks good (or you go too far and it pinches the paper and jams *not good*)
Feb 16, 2010 | IBM Infoprint 6500 Matrix Printer
Greyish marbeling on printed page & yellow wash allover page.
Sounds like you're probably running compatible cartridges. I sell a fair number of these cartridges to my customers, and it took a while to find a brand that actually worked. If you're seeing toner all over the place, the cartridges are most definitely the problem.
May 18, 2009 | HP Color LaserJet 2600n Printer
Canon pixma ip3000 print problem
tthanks about that but i dont know how to deel with that
Dec 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer is leaving black ink marks all over paper. Only happens from one tray. What can be done? I ran a cleaning page through and tried to clean the rollers.
Is there any way you can post an image of a page. If you can't I'll need to have a vivie description of these marks: -Where they are located. - general shape - location - any pattern - are they getting lighter the more you print. Once we get this information we can start troubleshooting.
Jan 22, 2007 | HP LaserJet 8000 Printer
HP LaserJet 1020 Printer Logo
308 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
